wrong system time after reboot
jpouyaud2
Re: wrong system time after reboot **solved**
Post by jpouyaud2 »
Hi lorenz1982
I confirm I've the same issue.
it's occurs sometime...
check your raw sample (for this timeline), they have been corrupted as meteobridge is not aware it's not synced yet with the right time
cheers
lorenz1982
Post by lorenz1982 »
jpouyaud2 wrote: Wed Jan 26, 2022 11:54 pm Hi lorenz1982
cheers
Yes the old data is overwritten.
MeteoBorgo: www.meteoborgo.it
What HW platform are you operating on?
lorenz1982
admin wrote: Thu Jan 27, 2022 2:23 pm What HW platform are you operating on?
I have a meteobridge installed on Raspberry Pi 3 Model B +. First I had the TP-LINK and I have recovered the settings.
lorenz1982
Today I rebooted to install the update and the date went back to January 12, 2022.
Immagine 2022-02-02 141130.jpg (116.24 KiB) Viewed 3960 times
jpouyaud2
Post by jpouyaud2 »
This is also what I've reported.
The jump in the past was related to previous reboots. (nothing more consistent).
After each jump in the past, the DB was corrupted and I've spend 1h to find and erase the wrong minute record
cheers
jpouyaud2
Post by jpouyaud2 »
This is why I've requested a feature where the Meteobridge SW start to record RAW only when an ntpq confirm the ntp client is synced to an NTP server with a "*"
after the boot, we should start with "ntpdate" then "ntpd" sync to 2 servers min
I don't know the feasibility with OpenWRT.
if it works it will be much more rock solid
just released update should have the issue fixed.
jpouyaud2
Post by jpouyaud2 »
cool !!
thank you
jpouyaud2
Post by jpouyaud2 »
ok
I've just upgraded
Reboot
and all green
first time I've a clock synchronized after the first reboot
looks promissing
jpouyaud2
Post by jpouyaud2 »
Hi
problem still present
did a reboot this evening for a maintenance
unfortunately the meteobridge reboot at the time of the last reboot (yesterday -24h) and wrote the DB in the past
after a second reboot. prb solved
please, before write the DB, check if the time is accurate
Capture d’écran 2022-02-05 à 21.10.08.png (262.98 KiB) Viewed 3880 times
Capture d’écran 2022-02-05 à 21.09.59.png (449.54 KiB) Viewed 3882 times
Version 5.3 should have this solved. If not please send credentials for remote login again to "into(at)meteobridge.com".
jpouyaud2
Post by jpouyaud2 »
Oki,
I've activated the remote login
looks like this issue occurs when the reboot is after let's say 1 day after the previouvs reboot but It's not 100% the case..
I still think this is solved. But lets wait a few days if newest version still show issues.
