Meteobridge communication problem with the UV sensor!
zakos52
Re: Meteobridge communication problem with the UV sensor!
Post by zakos52 »
Referring to the Live data Signal being in the sub -20db, such as UV signal of -14db and -18db? Have a couple of systems that literally sit on top of each other in repeater and non repeater configs and see around -40db signal strength so looking at what might appear odd or abnormal in your config.
The problem is when trying to diagnose something like this one only get to see what limited output is provided.
Sorry, but I didn't understand your answer!
My English is not very good
wsnoordbergum
Post by wsnoordbergum »
Have you tried not using the retransmit of the Vue console?
So directly receive from ISS?
Might be that the console is the culprit
zakos52
Post by zakos52 »
The problem also exists in the direct reception from the ISS.
The console is fine.
There is also a second console!
Thanks for your interest
zakos52
Post by zakos52 »
UV 30JUN2024.png (14.35 KiB) Viewed 3972 times
Every day 3 to 6 gaps in the UV chart!
I hope the admin solves this problem!
zakos52
Post by zakos52 »
uv 1jul2024.png (11.96 KiB) Viewed 3953 times
Today 7 gaps in the UV chart!
zakos52
Post by zakos52 »
UV 10 JUL 2024.png (11.53 KiB) Viewed 3882 times
I'm waiting for some upgrade that will solve the gap problem!
The admin is listening?
This continues to appear to be some sort of localized issue as so far unable to duplicate? Going back to basics and referring back to the graphs as you have not provided the raw logged data.
The Davis USB logger is directly connected to Davis WeatherLinkPC correct? What is the WLPC Archive Interval setting? Similar with the MB, what logging interval?
zakos52 wrote: Wed Jul 10, 2024 8:08 pm The admin is listening?
Are you really complaining about a few single minutes drop-out in UV data reception during the day? That can be anything. If you use a 5min scale for your graphs the gaps will not be there. Other systems (even Davis) might just repeat old data for a longer time to hide that no new data is there and to give easy to concern users some better sleep ;-)
zakos52
Post by zakos52 »
I'm not complaining, I just thought you could solve this problem, but I'm sorry to say that you just ignore it!
Why are there no gaps in the one minute-scale diagrams of temperature-humidity, barometer, wind, rain?
zakos52 wrote: Thu Jul 11, 2024 9:41 pm Why are there no gaps in the one minute-scale diagrams of temperature-humidity, barometer, wind, rain?
Because UV sensor is not sending data every minute.
zakos52
Post by zakos52 »
UV sensor sending data from 50 sec to 1min! (5 minutes when dark)
UV SPEC.png (23.13 KiB) Viewed 3852 times
Inspecting RF I have a different observation, but I guess you may know better.
Please excuse, that I put my focus on other topics.
zakos52
Post by zakos52 »
Please read 6490_SS.pdf from Davis (UV Sensor Specifications)
https://cdn.shopify.com/s/files/1/0515/ ... 490_SS.pdf
This is going nowhere. Topic closed.
Summary for the public: There is one user who experienced that in his special setup UV data might miss out a few minutes a few times a day. Please be warned!
