Trigger Event
davidmc36
Re: Trigger Event
Post by davidmc36 »
Mattk wrote: Sat Sep 06, 2025 6:17 am Then how about setting up an Email event at a Specific Time [18:00] with a Subj# Body something like
Frost Risk @ [[hh]:[mm]##if# {*(Condition1) && (Conditon2) && (Condition3)*} #then# Yes #else# No #fi#
I noticed on received emails there was a leading square brace before the time on subject line.
I removed the extra one.
Mauricio
Re: Trigger Event
Post by Mauricio »
Thank you very much for the detail David, t's true, it came out with a square at the beginning.
Mauricio
Re: Trigger Event
Post by Mauricio »
I'm thinking about setting up risk trigger events or forest fire early warnings perhaps thinking about the Australian MacArthur model (FFDI) or another model. Does anyone already have something set up that they could please point me to? Thanks
davidmc36
Re: Trigger Event
Post by davidmc36 »
All the data points can have selectors of daily max, monthly max, yearly max, or averages, or minimums.
With the basic template posted by Matt you could monitor every [your choice frequency] the accumulation of temp, rain, wind for example and set an alarm condition. Hot, no rain, lots of wind.....DING DING DING!
Check all the options:
https://www.meteobridge.com/wiki/index. ... =Templates
davidmc36
Re: Trigger Event
Post by davidmc36 »
I am using this to monitor if it is too sunny to be out:
 Sun Exposure @ [hh]:[mm]##if# {*([sol0rad-havg] >=150.0) && ([uv0index-havg] >=1.5) && ([sol0total-dmax=h] >=3.0)*} #then# Exposure High #else# Low Danger #fi#
I set it to check "before every 3rd full hour"
Seems fairly realistic.
Re: Trigger Event
That would be appropriate if the check was "before every full hour", "before every 3rd full hour" and using -havg which is the average value of this hour then at every 3 hours you you are only looking at the past hour and if that is what you expect then all is good?
If you actually wanted the average for the 3 hour period "before every 3rd full hour" then you would have to do something different?
davidmc36
Re: Trigger Event
Post by davidmc36 »
That's right. I check the most recent hour with this method. Every two hours is the next best choice. I have not decided which I like best.
