Trigger Event
Mauricio
Trigger Event
Post by Mauricio »
As we know, dew point temperatures can be used to predict when a severe frost will occur.
Therefore, I need help generating a trigger that will activate an alert indicating the possibility of a severe frost if the wind is =<5 km/h, the air temperature at 6:00 PM is >7.2°C, and the dew point is =< −2.2°C .
Is this possible? What do you think? Thanks!
davidmc36
Re: Trigger Event
Post by davidmc36 »
One thing is you can create an email event at that time of day sending those parameters.
What about email "Triggered By Event"?
Mauricio
Re: Trigger Event
Post by Mauricio »
Exactly! if an email can be generated at that time, any idea how can the variable be generated?
davidmc36
Re: Trigger Event
Post by davidmc36 »
I only had a quick look at the options under the Services/Events tab. Not sure exactly how to work it up.
Mauricio
Re: Trigger Event
Post by Mauricio »
I have tried it this way and it works!
One - Time Alarm ( It does not allow you to select 18 PM)
Raise: ([th0temp-act=c.1:0] <= 7.2) && ([wind0wind-act=kmh.0:0] <=5) && ([th0dew-act.0:0] <=-2.2)
Clear: ([th0temp-act=c.1:0] >= 10) && ([wind0wind-act=kmh.0:0] >=8.0) && ([th0dew-act.0:0] >= 2)
Subj # Body: Risk of severe frost!! 🔴
Re: Trigger Event
You should be able to frame a specific time and the other conditions using #if# #then# #else# #fi# and send an email etc?
Mauricio
Re: Trigger Event
Post by Mauricio »
Do you have any ideas on how to do it? I'm already lost there , I don't know how to relate it to the time. Thanks
davidmc36
Re: Trigger Event
Post by davidmc36 »
Mattk wrote: Sat Sep 06, 2025 1:46 am You should be able to frame a specific time and the other conditions using #if# #then# #else# #fi# and send an email etc?
Are you thinking of a virtual sensor with the desired conditions that triggers when all conditions are met and initiates the email?
Or would it all be done on the Event tab?
Mauricio
Re: Trigger Event
Post by Mauricio »
I want to develop it through an event
Re: Trigger Event
On the event tab but thinking some more might not be be an option without being able to nest the expression?
But with the one time alert maybe also able to incorporate the time (just thinking again) but just to clarify does the 6:00 PM only relate to the Temp? Assuming it would be, and wind, and dewp, and Temp all at 6:00 Pm? or No?
Mauricio
Re: Trigger Event
Post by Mauricio »
Exactly the time ( 18 PM) relate it to the 3 parameters
Re: Trigger Event
Then how about setting up an Email event at a Specific Time [18:00] with a Subj# Body something like
Frost Risk @ [[hh]:[mm]##if# {*(Condition1) && (Conditon2) && (Condition3)*} #then# Yes #else# No #fi#
Mauricio
Re: Trigger Event
Post by Mauricio »
Mattk, It's already working perfectly. Your event will help protect our crops from the risk of severe frost; it's excellent. Thank you very much!
davidmc36
Re: Trigger Event
Post by davidmc36 »
If I wanted to make an alarm that included Solar Radiation, UV Index, and Sunshine duration, how would you fill in the X's? Especially the watts per sq meter??
[sol0rad-act=x.X:X] <= n.n [uv0index-act=x.X:X] <= n.n [sol0total-act=x.X:X] <= n.n
Mauricio
Re: Trigger Event
Post by Mauricio »
A problem that I have encountered is that every time my device, the trigger, gives the order to reboot daily with http://templates.meteobridge.com/reboot.sh it trigger a rain event (false).
Thanks for any help or ideas on how to fix this.
