Aurora 2026 Rev-4.4Q Release
Re: Aurora 2026 Rev1Q-2 Release
pwilman wrote: Sun Feb 08, 2026 10:37 pm Brian,
Latest update seems to throw up an error for me in reference to line 5 of settings.php which seems to be about the variable "theme". It kicks in when you go into the setup screen. I added in the station name and clicked save. The error then appeared when you go into the main webpage.
I have reverted back to the previous verion (K) and everything is back to normal.
Paul
Good Morning Paul
ok no problem added back in theme option but not sure need to look closer to understand why that caused an error .
also added updates penned for next weekend as Im not around this week have a old school friend coming to stay till Friday been 40 years since I last seen him ..
Simple Update Aurora-Rev1Q-2 Monday afternoon 9th Feb https://www.mediafire.com/file/p3y2xhgl ... 2.zip/file
Master Download Aurora-2026-Rev1Q-2 https://www.mediafire.com/file/j6xcv0cl ... 2.zip/file
1.Updates simple update screen
2. re adds the theme dark/light in setup screen
3.numerous IOS pop up adjustments ..slowly getting there.
alexvanuxem
Re: Aurora 2026 Rev1Q Release
Post by alexvanuxem »
Hi Brain,
Thanks for the 1K update!
The errors i got previously are gone, got some new ones, see attached.
cheers
Alex
php.zip
(1.5 KiB) Downloaded 54 times
alexvanuxem wrote: Mon Feb 09, 2026 12:42 pm Hi Brain,
cheers
Alexphp.zip
Hello
sorry its its a quick short answer use the updated simple update Rev-1Q-2 from links above
see screenshot of your log below you have many cumulus errors and leftovers from older versions of template .
AL7CR
Post by AL7CR »
I have the template installed on a Mac on my local network. I would appreciate a description of how to feed data from my NanoSD on the same network to the template. I believe it involves setting up an http event but I have been unable to find an explanation of how it is to be done and the syntax for it.
I appreciate the help and look forward to testing the new release.
alexvanuxem
hi,
thanks for the update, it resolves a lot of issues.
Attached a new php.log with some leftovers?
Also, if I want to see the charts, like 2026 feb, my website crashes and is not available anymore for 30-45 minutes, hence the 500 error you saw earlier in this thread;
thanks
Alex
https://sint-katelijne-waver-meteo.be/aurora/
php.zip
(673 Bytes) Downloaded 59 times
Re: Aurora 2026 Rev-1R-2 Release
Download Simple Update Aurora 2026 Rev-1R-2 Feb 15th 2026
https://www.mediafire.com/file/p4txgm7o ... 2.zip/file
Master Download Aurora 2026 Rev-1R-2
https://www.mediafire.com/file/is30w4vn ... 2.zip/file
new stuff FEBRUARY 10TH-14th
in menu added units circle colour highlighting current unit in menu(adds blue circle to current unit)
added go to top arrow (helps in mobile layout portrait)
reworked all modules with title and chart icons
reworked WU forecast page
removed unused CSS (quite common to build up a lot of unused css when developing/compiling
improved CSS grid layout structure for all modules
corrected all modules max/min appearance
reworked all icons colouring
removed unused jQuery scripts
added future custom beta modules code ( not active looking for ideas of additional personal weather station data, sorry no offsite iframe data, no scraping of data from sources must be personal data owned by you or registered to you to use !! )
reworked simple update screen
reworked Woodsmoke descriptions for Airlink and Purple Air bottom small modules
updated webcam section of setup screen
added webcam location show yes or no
added webcam location description to setup screen
(for your privacy concerns you can disable this being shown via the new setup screen option show location yes/no)
added Air quality mask icon for 150 and above
added optional second sun moon module
todo
(Ramadan month begins 19th February ,for me this is a quiet month locally good time to do things like this)
1. custom modules options in setup screen
2.write up how to create a short dedicated second API to run additional sensors not present in master API output
3.open to ideas to improve overall experience and visuals
@ALEX as per previous post simply delete those files listed in your php.zip there out of date unused
pwilman
Re: Aurora 2026 Rev-1R Release
Post by pwilman »
With this update I think this version is looking really crisp. Best one yet.
Only thing I can see is that using chrome on my Mac the top of the screen is slightly cut off. The top of the setting screen icon is chopped off on mine (www.paulwilman.com/W34)
Other than that it all loks great
Paul
pwilman wrote: Sun Feb 15, 2026 5:57 pm Brian,
Paul
Good evening paul
thanks my bad for not using chrome !
should be fine now see screenshots below using chrome on mac simple one line removal of css :-(
also includes new second optional sun/moon module with graphic sun position in setup screen see below
pwilman
Post by pwilman »
Thank you so much for such a quick response. You must go crazy with all the different browser and device settings!!!!
Paul
Re: Aurora 2026 Rev-1S Release
Download Simple Update Aurora 2026 Rev-1S 21ST February 2026
https://www.mediafire.com/file/z19h824n ... S.zip/file
Download Master Aurora 2026 Rev-1S 21ST February 2026
https://www.mediafire.com/file/1keirhzu ... S.zip/file
1.lots of css tweaks to suit many of the iPhone/iPad Series
2.lots of unused/leftovers( mostly from original template) now removed
3.@Daniel please use this forum thread to report issues .. fixed iPhone screen width thanks..
screenshots
doesn't display all but went through iPhone 11 to iPhone 16 pro max and iPad mini to iPad 12 series
did someone ask me how to send meteobridge data to a local hosted server I'm guessing on a home PC or laptop ?
if so let me know again its not for the faint hearted or inexperienced and its definitely not a 100% reliable but if you want a challenge .
if its for Mac I maybe able to help if its windows I haven't a clue ..
Brian
xxvincixx
Post by xxvincixx »
Hi Brian, I haven't installed the new dashboard yet. I was wondering if there was an option to place the clock in one of the positions i highlighted. And if not, if it could be integrated. Thanks for your work.
good morning
no problem will add an option in the setup with module..
Brian
xxvincixx wrote: Sat Feb 21, 2026 7:45 pm Hi Brian, I haven't installed the new dashboard yet. I was wondering if there was an option to place the clock in one of the positions i highlighted. And if not, if it could be integrated. Thanks for your work.
good morning
added large clock option but NOTE do not run large clock and small clock simultaneously !!!!
will release next weekend in simple update ..Brian
screenshots
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Sun Feb 22, 2026 8:40 am
good morning
screenshots
thanks Brian ;)
Re: Aurora 2026 Rev-1T Release
Download Master Aurora-2026-REV-1T-2
https://www.mediafire.com/file/jehodk21 ... 2.zip/file
Download Simple-Update-Aurora-2026-REV-1T-2
https://www.mediafire.com/file/mi5wz5xr ... 2.zip/file
Feb 22- 1st March Aurora 2026 Rev - 1T-2
1. Added large clock module ..requested
2. Fixed today charts showing purple air if set to NO in setup .requested
3. Fixed year charts showing month data when clicking icon for larger view .requested
4. Added last updated time for Offline Notification ..requested
5. Verified PHP 8.5 release compatibility ..requested
6. Cleaned and Simplified Setup Login page
7. Reworked setup screen css for easier implementation of new ideas/custom modules
8. Cleaned out unused code for 232 PHP files !!
9. Added new Aurora 2026 icon
10. License module reworked to reflect meteobridge hardware in use
11. Fixed not showing correct image for meteobridge pro models
12. If your PHP version in use is less or lower than PHP 8 you will see a PHP required upgrade message in setup login screen
13. Added alert icon to fire risk , heat-index , earthquakes
14. Re compiled chart layouts in dashboard modules
15. Optimized light theme for IOS devices
16. Added caution icons when threshold of high or below is met examples dew point is above 21c or 69F or low humidity below 20%
17. Added support for Apple Watch Ultra 1/2/3 and series 9-11 .* note main page only !! simplified menu & sensor view..
18. Added new icons for majority of modules
19. Recompiled Webcam script
20. New FAVICON for browser etc
21. Fixed local Metar temperature color
22. Fixed WU forecast temperature color
23. Fixed non metric(F) temperature ICON
24. Fixed Chrome Browser alignments in small bottom modules
Todo ..custom module how to use and configure meteobridge PDF
