Page 22 of 30
Posted: Fri Dec 29, 2023 10:21 am
by meteolive57290
weatherist34 wrote: Thu Dec 28, 2023 5:38 pm ok i saw it in the email, i placed my PA api key and again nothing so definitely server related to that file , as a test set all permissions on that purpleair.txt file 777 just as a test
then run yourdomain/pws/mbdbfiles/stationcron.php
hello obviously it continues not to work even with your instructions systematically I have an empty .txt file and no data recovery in the block_template :?: :?: Regards
Posted: Fri Dec 29, 2023 10:34 am
by weatherist34
good morning
you have a localised issue what it is I dont know and not possible for me to diagnose unless you want to provide FTP access thats all I can offer, all sites using purple air use the exact same script and nothing has changed in how purple air modules collects the data via the API since introduction of CO2(VOC) which at a guess was 2020-21 so same script still in use. some examples below..brian
https://singaporeweather.info/weather34-full-layout.php
https://woolfg.hyperphp.com/Ringwood/we ... layout.php
https://whaleybridge-weather.com/weathe ... yout-2.php
ps was you the same guy/user from weather display many years ago(year 2016 at a guess) if so I seem to remember there were some specific issues related to your sites forgive me if Im wrong ..
Posted: Fri Dec 29, 2023 10:57 am
by ToTo
Hello Brian,
my opinion to theme 8, if the compass is no longer displayed round, then please display a range of degrees.
As if you were looking at the compass from the front:
Posted: Fri Dec 29, 2023 12:15 pm
by lorenz1982
Small problem on both Chrome and iOS.
Posted: Fri Dec 29, 2023 12:19 pm
by meteolive57290
weatherist34 wrote: Fri Dec 29, 2023 10:34 am good morning
:| I found in my archives a backup from January 2022 where the PurpleAir script was functional for me for the same sensor
without referring to the new API and mentioning that I have not modified in my hosting setup??
an inspection I think will not give much!! what continues to concern me is that each time the "stationcron" is launched manually
I systematically have a null .txt file AND ONLY for this script?? and this exclusively after updating the template (after prolonged inactivity on my part)
Posted: Fri Dec 29, 2023 12:26 pm
by weatherist34
ToTo wrote: Fri Dec 29, 2023 10:57 am Hello Brian,
Hello Torsten
all noted lets see how it evolves , i can try and if it works without becoming messy or unbalanced ill implement it.
as it is now it is very easy to maintain/modify by end user .
@Lorenzo all noted ..be nice if you report back when changes are made sometimes I need the input due to different weather sensor scenarios around the world, will change it in time for next update..
@meteolivexxxxx provide FTP access via mail i will look closer but I can assure you nothing changed in respect to purple air otherwise multiple users would be highlighting same issue your seeing.
as it is now , in the temperature module there are three scenarios feels like, windchill , heat index obviously based on localised seasonal changes.
if no UV max greater than zero the chart shows solar data if greater than zero again seasonal for those who live north of watford gap (northern hemisphere) :-)
Posted: Fri Dec 29, 2023 12:58 pm
by weatherist34
lorenz1982 wrote: Fri Dec 29, 2023 12:15 pm Small problem on both Chrome and iOS.
Lorenzo next update
Posted: Fri Dec 29, 2023 1:19 pm
by meteolive57290
weatherist34 wrote: Fri Dec 29, 2023 12:26 pm @meteolivexxxxx provide FTP access via mail i will look closer but I can assure you nothing changed in respect to purple air otherwise multiple users would be highlighting same issue your seeing.
:wink: thnx okay Brian i just @ you right away :arrow: Regards
Posted: Fri Dec 29, 2023 1:38 pm
by weatherist34
thanks got the ftp and now ok its working now you had a very old stationcron file see below ,ive added the most recent script your existing script was either modified or just way old method.dont know but sometimes i need closer access to diagnose , it was to easy to spot ..have a good day..brian
https://valdefench57sgz.franceserv.com/ ... pleair.txt timestamp below Friday, 29 December 2023 11:31:19
  "api_version" : "V1.0.11-0.0.49",
  "time_stamp" : 1703849479,
  "data_time_stamp" : 1703849458,
  "sensor" : {
    "sensor_index" : 47165,
    "last_modified" : 1612601115,
    "date_created" : 1580166309,
    "last_seen" : 1703849455,
    "private" : 0,
    "is_owner" : 0,
    "name" : "Valdefensch57@Meteolive OUTSIDE",
    "icon" : 0,
    "location_type" : 0,
    "model" : "PA-II",
    "hardware" : "2.0+BME280+PMSX003-B+PMSX003-A",
    "led_brightness" : 35,
    "firmware_version" : "7.02",
    "rssi" : -60,
    "uptime" : 13660,
Posted: Fri Dec 29, 2023 1:46 pm
by lorenz1982
weatherist34 wrote: Fri Dec 29, 2023 12:58 pm
Lorenzo next update
Thanks for everything you do.
Posted: Fri Dec 29, 2023 3:56 pm
by weatherist34
Torsten
taken the compass layout from the airport popup ..is this something better than text ???
i dont have the enthusiasm to compile brand new stuff when there a few alternatives in the various layouts ..brian
Posted: Fri Dec 29, 2023 5:07 pm
by ToTo
I like it, thank you. :)
Posted: Fri Dec 29, 2023 6:28 pm
by weatherist34
ToTo wrote: Fri Dec 29, 2023 5:07 pm I like it, thank you. :)
ok cool that was relatively easy .. any other ideas ? a bit of time on my hands at the moment wife has "MAN FLU" so some isolation all over again :( ...
ended up like this which is very easy to maintain ..
Posted: Fri Dec 29, 2023 6:55 pm
by meteolive57290
weatherist34 wrote: Fri Dec 29, 2023 1:38 pm thanks got the ftp and now ok its working now you had a very old stationcron file see below ,ive added the most recent script your existing script was either modified or just way old method.dont know but sometimes i need closer access to diagnose , it was to easy to spot ..have a good day..brian
:wink: :wink: thank you very mutch Brian for your assistance and availability okay i just saw it seems to be working correctly again now.... know it when we see that it had little to do with it :) - thank you again and very happy end of 2023 holidays to You and family and everyone :wink:
Posted: Fri Dec 29, 2023 7:37 pm
by ToTo
Ideas? of course ;-)
+ The diagrams for the air quality in Theme 8 are still missing.
+ We now have a lot of themes, it would be nice if the currently selected theme number in the menu could be identified with a different color.
+ The menu in Theme 8 overlaps the footer.
+ The font size in the menu changes between different themes, I find the font size in the menu of Theme 5 suitable?
