is it ok now?weatherist34 wrote: Wed Jan 06, 2021 6:56 am good morning simon thank you getting there . i noticed your site always says offline ?
- ConligWX
Regards Simon
https://www.conligwx.org/pws
- ConligWX
browser at 100%? have you tried a different browser or even CTRL-F5 (refresh)Taralas wrote: Wed Jan 06, 2021 10:12 pm Anyone else getting a display anomaly with the Jan 6th update for MKII?
I included the previous version as well, from December 31st.
I am able to revert to the previous version, but I am wondering what is causing the issue.
Thanks in advance.
Regards Simon
hi go into setup settings screen and select the correct barometer-mod.php this looks like it is attempting to load old barometermod.php from previous version.Taralas wrote: Wed Jan 06, 2021 10:12 pm Anyone else getting a display anomaly with the Jan 6th update for MKII?
Thanks in advance.
@simon no always offline .
@simon correction showing online
@Taralas barometer module your using is not available in MKII any longer this was a leftover from beta release a week or so ago ,over the last week or so most leftovers and unused code has been removed from MKII version hence daily updates it just takes time to ween em out
but this morning 7th update is the last for a while unless someone discovers a major flaw / error . end of month expect a new API structure with new additional data .The new API is 50% done and includes many new strings replacing older strings no longer used . But thats and end of month target. for now I would just update and enjoy the template if it is to your liking.
ps thank you for all the emails Im sorry I dont have time to answer all immediately but I will .
I re iterate donations are not required its flattering but unnecessary I refuse to put a price tag on time I spend on this, the moment money comes into the equation its then to me it is not a hobby,hobbies are a pastime..your donation is being collaborative, constructive ideas for others to benefit and finding my errors..
FWIW doing this actually helps me learn and do other design work where I have charged in recent weeks for private clients which are not weather related so to me thats my return for doing this .
have a good day all...Brian
- prestwickwx
MKII is looking great.
Thanks for all of the recent updates.
Best wishes and stay safe.
@weather
That was it exactly. Thank you!weatherist34 wrote: Thu Jan 07, 2021 8:35 am @Taralas barometer module your using is not available in MKII any longer this was a leftover from beta release a week or so ago ,over the last week or so most leftovers and unused code has been removed from MKII version hence daily updates it just takes time to ween em outbut this morning 7th update is the last for a while unless someone discovers a major flaw / error . end of month expect a new API structure with new additional data .The new API is 50% done and includes many new strings replacing older strings no longer used . But thats and end of month target. for now I would just update and enjoy the template if it is to your liking.
every time I decide too take a short break something appears in an email that needs fixing or an idea comes to mind .
update 09-01-2021
air quality and other notifications are totally optional
forecast awareness only appears every 15 minutes as it has its own notification driver !
* Adds Davis Air Quality notifications if greater than 100 (3:48pm).
* Adds Purple Air Quality notifications if greater than 100 (3:48pm).
* Forecast icons awareness notifications alignment (6:51am).
update 09-01-2021
- prestwickwx
I see you have added MKII to Git.
Let me know if you would like me to use Git rather than the simple update.
Best wishes,
Best wishes,
hello chuck entirely upto you . i added a github extension for vsc application https://code.visualstudio.com/ so it simply prompts me to update Github repo automatically or when I choose to directly from the application itself. basically the github is a master file for those who are confident in using github as the source. github master is always identical to main download and contains all updates in the simple update. for those who prefer github https://github.com/weather34/Weather34-AuroraMKII
alexeysailman
- Expert Boarder
Hi, Brian! Here is something else on the attached picture:
- a circle on the bottom right, I think everything is visible.
- trend with atmospheric pressure, at selected mmHg in hpa (and in "extra" the same).
- about the numbers 1, 2, 3: will it be possible to select trends in the settings at the bottom of the screen when you click the dayli charts button? Say if I still have UV and AQI? And in general, independently compose trends and change their order?
- pic.JPG (343.09 KiB) Viewed 5114 times
alexeysailman
- Expert Boarder
I came across another interesting point: the picture " pic " is a screenshot from the weather dashboard, directly from the meteobridge itself. So there is a pressure of 764.4 mm Hg. column, and in the screenshot "pic 2" c weather34 template 763.5 mm Hg. column. Both screenshots were taken at the same time. I also checked the atmospheric pressure in meteobridge itself. In general, the atmospheric pressure on the console=meteobridge weather dashboard, but for some reason it is different in the template.
- pic2.JPG (241.01 KiB) Viewed 5111 times
- pic.JPG (254.11 KiB) Viewed 5111 times
simple update 10th January update attempts to fix mmHg display in charts your other issues ill try and replicate in the week. please just run the update for MKII.
thats all I can do for now. mmHg is only displayed when unit is Celsius and mmHg is selected as pressure unit in setup.
Brian ..
Brian ..
- prestwickwx
Hi Brian,weatherist34 wrote: Sat Jan 09, 2021 4:45 pm hello chuck entirely upto you . i added a github extension for vsc application https://code.visualstudio.com/ so it simply prompts me to update Github repo automatically or when I choose to directly from the application itself. basically the github is a master file for those who are confident in using github as the source. github master is always identical to main download and contains all updates in the simple update. for those who prefer github https://github.com/weather34/Weather34-AuroraMKII
Ok. Just wanted to see which might help you.
The latest simple update does include 3 updated files (below) that were not in the Git commit.
Thanks again,
hi chuck I was waiting to see if he was going to comment back but anyway just pushed those 3 but its only related to mmHg.prestwickwx wrote: Sun Jan 10, 2021 3:57 pmHi Brian,weatherist34 wrote: Sat Jan 09, 2021 4:45 pm hello chuck entirely upto you . i added a github extension for vsc application https://code.visualstudio.com/ so it simply prompts me to update Github repo automatically or when I choose to directly from the application itself. basically the github is a master file for those who are confident in using github as the source. github master is always identical to main download and contains all updates in the simple update. for those who prefer github https://github.com/weather34/Weather34-AuroraMKII
Thanks again,
- rzelle-K1TTC
Looks like I updated to MKII successfully so far. I had a problem with getting GitHub switched to the new repository but it looks like it's working now.
All looks Great! for MKII ...
Very Busy here with work and home related LAN projects.
Hope all is well ..
73s
..Ron
Hope all is well ..
73s
..Ron
