Re: Ecowitt GW1000 and Meteobridge
Posted: Fri Jun 12, 2020 7:36 pm
I triggered the 4 leak sensors and the leaks registered on the ambient website and I got 4 email alerts, one for each of the triggered sensors
Still happening after update here. less frequently, but still happening.galfert wrote: Fri Jun 12, 2020 2:56 pm Yes I had discussion with Ecowitt to explain the findings that Boris discovered. They responded quick!
Yeah dunno.galfert wrote: Sat Jun 13, 2020 1:55 am I'm going on 11 hours since 1.6.0 firmware install and it hasn't had any issues even once. No data loss. I'm set to catching it also via MB alert trigger. ¯\_(ツ)_/¯
logger (17.06.2020 03:29:53): unexpected 0 bytes.
logger (17.06.2020 03:29:53): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:30:23): connect station 0 (GW1000 via th).
logger (17.06.2020 03:30:23): unexpected 0 bytes.
logger (17.06.2020 03:30:23): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:30:53): connect station 0 (GW1000 via th).
logger (17.06.2020 03:30:53): unexpected 0 bytes.
logger (17.06.2020 03:30:53): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:31:23): connect station 0 (GW1000 via th).
logger (17.06.2020 03:31:23): unexpected 0 bytes.
logger (17.06.2020 03:31:23): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:31:53): connect station 0 (GW1000 via th).
logger (17.06.2020 03:31:53): unexpected 0 bytes.
logger (17.06.2020 03:31:53): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:32:23): connect station 0 (GW1000 via th).
logger (17.06.2020 03:32:23): unexpected 0 bytes.
logger (17.06.2020 03:32:23): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:32:53): connect station 0 (GW1000 via th).
logger (17.06.2020 03:32:53): unexpected 0 bytes.
logger (17.06.2020 03:32:53): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:33:23): connect station 0 (GW1000 via th).
logger (17.06.2020 03:33:23): no valid signal for 300 seconds, data logger will be restarted.
logger (17.06.2020 03:33:23): disconnect station 0 (GW1000): exit
logger (17.06.2020 03:33:23): data logger stopped.
logger (17.06.2020 03:33:23): historical data loaded (69 records).
logger (17.06.2020 03:33:23): data logger (version 5.1d, build 3113) started.
logger (17.06.2020 03:33:24): connect station 0 (GW1000 via TCP/IP).
logger (17.06.2020 03:33:27): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (17.06.2020 03:33:27): services paused.
logger (17.06.2020 03:33:34): sensors are now providing data.
logger (17.06.2020 03:33:34): services started.
system (17.06.2020 03:33:44): stop of logging process initiated.
system (17.06.2020 03:33:52): start of logging process initiated.
logger (17.06.2020 03:33:52): historical data loaded (69 records).
logger (17.06.2020 03:33:52): data logger (version 5.1d, build 3113) started.
logger (17.06.2020 03:33:52): connect station 0 (GW1000 via TCP/IP).
logger (17.06.2020 03:33:56): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (17.06.2020 03:33:56): services paused.
logger (17.06.2020 03:34:03): sensors are now providing data.
logger (17.06.2020 03:34:03): services started.
logger (17.06.2020 03:34:03): message above repeats 1 time.
logger (17.06.2020 03:38:20): connection reestablished.
logger (17.06.2020 03:38:20): unexpected 0 bytes.
logger (17.06.2020 03:38:20): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:38:50): connect station 0 (GW1000 via th).
logger (17.06.2020 03:38:50): unexpected 0 bytes.
logger (17.06.2020 03:38:50): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:39:20): connect station 0 (GW1000 via th).
logger (17.06.2020 03:39:20): unexpected 0 bytes.
logger (17.06.2020 03:39:20): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:39:50): connect station 0 (GW1000 via th).
logger (17.06.2020 03:39:50): unexpected 0 bytes.
logger (17.06.2020 03:39:50): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:40:20): connect station 0 (GW1000 via th).
logger (17.06.2020 03:40:20): unexpected 0 bytes.
logger (17.06.2020 03:40:20): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:40:50): connect station 0 (GW1000 via th).
logger (17.06.2020 03:40:50): unexpected 0 bytes.
logger (17.06.2020 03:40:50): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:41:20): connect station 0 (GW1000 via th).
logger (17.06.2020 03:41:20): unexpected 0 bytes.
logger (17.06.2020 03:41:20): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:41:50): connect station 0 (GW1000 via th).
logger (17.06.2020 03:41:50): unexpected 0 bytes.
logger (17.06.2020 03:41:50): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:42:20): connect station 0 (GW1000 via th).
logger (17.06.2020 03:42:20): unexpected 0 bytes.
logger (17.06.2020 03:42:20): disconnect station 0 (GW1000): response without data
logger (17.06.2020 03:42:50): connect station 0 (GW1000 via th).
logger (17.06.2020 03:42:50): unexpected 0 bytes.
logger (17.06.2020 03:42:50): disconnect station 0 (GW1000): response without data
system (17.06.2020 03:43:00): stop of logging process initiated.
system (17.06.2020 03:43:08): start of logging process initiated.
logger (17.06.2020 03:43:08): historical data loaded (69 records).
logger (17.06.2020 03:43:08): data logger (version 5.1d, build 3113) started.
logger (17.06.2020 03:43:09): connect station 0 (GW1000 via TCP/IP).
logger (17.06.2020 03:43:12): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (17.06.2020 03:43:12): services paused.
logger (17.06.2020 03:43:19): sensors are now providing data.
logger (17.06.2020 03:43:19): services started.
logger (17.06.2020 03:43:19): message above repeats 1 time.
logger (17.06.2020 10:12:15): connection reestablished.
logger (17.06.2020 10:12:15): unexpected 0 bytes.
logger (17.06.2020 10:12:15): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:12:45): connect station 0 (GW1000 via th).
logger (17.06.2020 10:12:45): unexpected 0 bytes.
logger (17.06.2020 10:12:45): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:13:15): connect station 0 (GW1000 via th).
logger (17.06.2020 10:13:15): unexpected 0 bytes.
logger (17.06.2020 10:13:15): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:13:45): connect station 0 (GW1000 via th).
logger (17.06.2020 10:13:45): unexpected 0 bytes.
logger (17.06.2020 10:13:45): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:14:15): connect station 0 (GW1000 via th).
logger (17.06.2020 10:14:15): unexpected 0 bytes.
logger (17.06.2020 10:14:15): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:14:45): connect station 0 (GW1000 via th).
logger (17.06.2020 10:14:45): unexpected 0 bytes.
logger (17.06.2020 10:14:45): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:15:15): connect station 0 (GW1000 via th).
logger (17.06.2020 10:15:15): unexpected 0 bytes.
logger (17.06.2020 10:15:15): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:15:45): connect station 0 (GW1000 via th).
logger (17.06.2020 10:15:45): unexpected 0 bytes.
logger (17.06.2020 10:15:45): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:16:15): connect station 0 (GW1000 via th).
logger (17.06.2020 10:16:15): unexpected 0 bytes.
logger (17.06.2020 10:16:15): disconnect station 0 (GW1000): response without data
logger (17.06.2020 10:16:45): connect station 0 (GW1000 via th).
logger (17.06.2020 10:16:45): unexpected 0 bytes.
logger (17.06.2020 10:16:45): disconnect station 0 (GW1000): response without data
system (17.06.2020 10:16:54): stop of logging process initiated.
system (17.06.2020 10:17:01): start of logging process initiated.
logger (17.06.2020 10:17:02): historical data loaded (69 records).
logger (17.06.2020 10:17:02): data logger (version 5.1d, build 3113) started.
logger (17.06.2020 10:17:02): connect station 0 (GW1000 via TCP/IP).
logger (17.06.2020 10:17:05): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (17.06.2020 10:17:05): services paused.
logger (17.06.2020 10:17:13): sensors are now providing data.
logger (17.06.2020 10:17:13): services started.
logger (17.06.2020 10:17:13): message above repeats 1 time.
logger (17.06.2020 23:51:19): connection reestablished.
logger (17.06.2020 23:51:19): unexpected 0 bytes.
logger (17.06.2020 23:51:19): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:51:49): connect station 0 (GW1000 via th).
logger (17.06.2020 23:51:49): unexpected 0 bytes.
logger (17.06.2020 23:51:49): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:52:19): connect station 0 (GW1000 via th).
logger (17.06.2020 23:52:19): unexpected 0 bytes.
logger (17.06.2020 23:52:19): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:52:49): connect station 0 (GW1000 via th).
logger (17.06.2020 23:52:49): unexpected 0 bytes.
logger (17.06.2020 23:52:49): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:53:19): connect station 0 (GW1000 via th).
logger (17.06.2020 23:53:19): unexpected 0 bytes.
logger (17.06.2020 23:53:19): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:53:49): connect station 0 (GW1000 via th).
logger (17.06.2020 23:53:49): unexpected 0 bytes.
logger (17.06.2020 23:53:49): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:54:19): connect station 0 (GW1000 via th).
logger (17.06.2020 23:54:19): unexpected 0 bytes.
logger (17.06.2020 23:54:19): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:54:49): connect station 0 (GW1000 via th).
logger (17.06.2020 23:54:49): unexpected 0 bytes.
logger (17.06.2020 23:54:49): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:55:19): connect station 0 (GW1000 via th).
logger (17.06.2020 23:55:19): unexpected 0 bytes.
logger (17.06.2020 23:55:19): disconnect station 0 (GW1000): response without data
logger (17.06.2020 23:55:49): connect station 0 (GW1000 via th).
logger (17.06.2020 23:55:49): unexpected 0 bytes.
logger (17.06.2020 23:55:49): disconnect station 0 (GW1000): response without data
system (17.06.2020 23:55:57): stop of logging process initiated.
system (17.06.2020 23:56:04): start of logging process initiated.
logger (17.06.2020 23:56:05): historical data loaded (69 records).
logger (17.06.2020 23:56:05): data logger (version 5.1d, build 3113) started.
logger (17.06.2020 23:56:05): connect station 0 (GW1000 via TCP/IP).
logger (17.06.2020 23:56:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (17.06.2020 23:56:09): services paused.
logger (17.06.2020 23:56:16): sensors are now providing data.
logger (17.06.2020 23:56:16): services started.
logger (17.06.2020 23:56:16): message above repeats 1 time.
logger (18.06.2020 06:24:49): connection reestablished.
logger (18.06.2020 06:24:49): unexpected 0 bytes.
logger (18.06.2020 06:24:49): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:25:19): connect station 0 (GW1000 via th).
logger (18.06.2020 06:25:19): unexpected 0 bytes.
logger (18.06.2020 06:25:19): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:25:49): connect station 0 (GW1000 via th).
logger (18.06.2020 06:25:49): unexpected 0 bytes.
logger (18.06.2020 06:25:49): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:26:19): connect station 0 (GW1000 via th).
logger (18.06.2020 06:26:19): unexpected 0 bytes.
logger (18.06.2020 06:26:19): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:26:49): connect station 0 (GW1000 via th).
logger (18.06.2020 06:26:49): unexpected 0 bytes.
logger (18.06.2020 06:26:49): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:27:19): connect station 0 (GW1000 via th).
logger (18.06.2020 06:27:19): unexpected 0 bytes.
logger (18.06.2020 06:27:19): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:27:49): connect station 0 (GW1000 via th).
logger (18.06.2020 06:27:49): unexpected 0 bytes.
logger (18.06.2020 06:27:49): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:28:19): connect station 0 (GW1000 via th).
logger (18.06.2020 06:28:19): unexpected 0 bytes.
logger (18.06.2020 06:28:19): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:28:49): connect station 0 (GW1000 via th).
logger (18.06.2020 06:28:49): unexpected 0 bytes.
logger (18.06.2020 06:28:49): disconnect station 0 (GW1000): response without data
logger (18.06.2020 06:29:19): connect station 0 (GW1000 via th).
logger (18.06.2020 06:29:19): unexpected 0 bytes.
logger (18.06.2020 06:29:19): disconnect station 0 (GW1000): response without data
system (18.06.2020 06:29:40): stop of logging process initiated.
system (18.06.2020 06:29:47): start of logging process initiated.
logger (18.06.2020 06:29:48): historical data loaded (69 records).
logger (18.06.2020 06:29:48): data logger (version 5.1d, build 3113) started.
logger (18.06.2020 06:29:48): connect station 0 (GW1000 via TCP/IP).
logger (18.06.2020 06:29:52): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 06:29:52): services paused.
logger (18.06.2020 06:29:59): sensors are now providing data.
logger (18.06.2020 06:29:59): services started.
wnetd (14.06.2020 08:47:50): process started.
system (14.06.2020 08:47:50): start of logging process initiated.
wnetd (14.06.2020 08:47:51): send data thread started (pid:2245 tid:2247)
logger (14.06.2020 08:47:51): historical data loaded (30 records).
logger (14.06.2020 08:47:51): data logger (version 5.1d, build 13564) started.
logger (14.06.2020 08:47:52): connect station 0 (GW1000 via TCP/IP).
logger (14.06.2020 08:47:55): sensors are now providing data.
logger (14.06.2020 08:47:55): services started.
Updated, we'll see if it happens again. Thanks!admin wrote: Thu Jun 18, 2020 7:51 pm Thanks for spotting this. It is a bug that can also impact the whole reconnect procedure. Just released update fixes this.
