Meteobridge supports Raspberry Pi 3B, 3B+, 4B
masgio69
Re: Meteobridge supports Raspberry Pi 3B, 3B+, 4B
Post by masgio69 »
Hi, but the software dedicated to the Raspberry 4B is the same as the meteobridge pro?
RPI equipped with a proper SD card can do all a MB PRO can do, except no RF data read out from Davis ISS and no display.
masgio69
Post by masgio69 »
Thank you so much for the reply, I'm waiting for it to come to try it .....
Xanti19
Post by Xanti19 »
When changing from TL-MR3020 to RPI, can I import the configuration file from MR3020 to RPI?
OK, it worked. :wink:
Another Question:
How do I export weather data to a file for weewx, or can I configure weewx so that the weather data can be queried via the Meteobridge IP?
Where is the data export, e.g. standard-imp, stored at the RPI?
With the ML3020 you could change the min/max data with a click. With the min/max data in the RPI, clicking on a value only opens a menu with hourly values. How can I change the min/max value?
captgadget
Post by captgadget »
I lost my ATP micro SD card and all I could find was SanDisk Industrial MLC MicroSD SDHC UHS-I Class 10 SDSDQAF3-008G-I. Will it work?
captgadget wrote: Fri Jun 30, 2023 7:53 pm I lost my ATP micro SD card and all I could find was SanDisk Industrial MLC MicroSD SDHC UHS-I Class 10 SDSDQAF3-008G-I. Will it work?
That is a cheap consumer card which will not stand the needed write cycles and will fail for sure after some time. Metobridge will also not accept it until you overwrite the lock.
josecmorales
Post by josecmorales »
MB works on a RPI 5?
@climaguayana
josecmorales wrote: Thu Jul 03, 2025 10:54 pm MB works on a RPI 5?
no
