Page 65 of 89
Forecast in Top-Line
Posted: Wed Sep 16, 2020 4:22 pm
by xray77
I have a question about the forecast in the top-line like this:
- Bildschirmfoto 2020-09-16 um 16.08.00.png (32.09 KiB) Viewed 4462 times
I haven't found some setting about this in the setup-screen.. How can I add this to my display-screen?
when I add the Indoor-module to bottom-line and click on the icon have the following screen:
- Bildschirmfoto 2020-09-16 um 16.14.37.png (507.48 KiB) Viewed 4462 times
How I can fix it or must I simply wait as the template add's the missing data?
Many thanks for tipps,
best regards
Michael
Re: Weather34 TEMPLATE
Posted: Wed Sep 16, 2020 4:56 pm
by weatherist34
the wu forecast in top line is based on if these are met its more of awareness not a forecast with all .
basically 'what if' statements then do something(show something)
if heat index >30
if temp <0
if rainfall accum>0
if snow accum>0
if thunder >0
if windspeed >37 mph (60km)
so if in the wu forecast the conditions are met it will appear .
- Screenshot at Sep 16 17-57-36.jpg (13.38 KiB) Viewed 4459 times
the 404 means two files are not present on your server todayindoormodulechart-large.php todayindoormodulechart-humidity-large.php which reside in the weather34charts folder.
please send me an email I can send you those two files to place in the weather34charts folder .
Posted: Wed Sep 16, 2020 5:05 pm
by xray77
Brian, thanks for your explanation to the additional forecast in top-line.
Have sent you my email-address via pm, ...and the missing files just arrived!
Now it works perfectly!
many thanks for your very fast response!
regards,
Mike
Posted: Wed Sep 16, 2020 5:16 pm
by weatherist34
good stuff , i will tweak the kts bar indicator tomorrow as watching your station for a few minutes i see its not aligned when using kts , forgive me but all kmh here .. so look for that tomorrow via simple update file from info page..have a nice evening ..
Posted: Wed Sep 16, 2020 5:46 pm
by xray77
Hello Brian,
...I had already seen the little issue in the kts-Bar, but I thought, I didn't want to bother you with that now...
And now you have already seen it yourself, thank you for the announced correction!
This is what I call support, really great and the fastest I ever seen, many thanks!!
best regards
Mike
Posted: Wed Sep 16, 2020 9:05 pm
by atlantic21
Have just setup a Luftdaten home made AQI Station, when in weather 34 consol settings do i put the full id of my station ( which is 7 numbers )
Richard
Posted: Wed Sep 16, 2020 9:14 pm
by weatherist34
is your station on the lufdaten map , I don't see any sensors in Ilfracombe
https://maps.sensor.community/#12/51.1507/-4.1226
generally its 4 or 5 id numbers
Posted: Wed Sep 16, 2020 9:25 pm
by atlantic21
No not on the map yet waiting but i can see it on the PM sensor-Grafana dashboard
- AQI.png (93.7 KiB) Viewed 4424 times
Posted: Wed Sep 16, 2020 9:39 pm
by weatherist34
so your ID 444O is OK check now don't forget it updates when the stationcron runs .
- ilfrac.jpg (54.45 KiB) Viewed 4422 times
have a nice evening
by atlantic21
OK i have it all working now with just the last 4 numbers
Posted: Thu Sep 17, 2020 7:16 am
by weatherist34
good morning Richard
are you sure that is your ID 4440 because if you look at this data like Lat/ Longitude its not ILFRACOMBE
https://data.sensor.community/airrohr/v1/sensor/4440/
[{"location":{
"longitude":"13.442","altitude":"39.9","id":2233,"exact_location":0,"country":"
DE","
latitude":"52.518","indoor":0},"sensordatavalues":[{"value":"2266.67","value_type":"P1","id":4086551538},{"value":"999.90","value_type":"P2","id":4086551612}],"timestamp":"2020-09-17 05:04:31","id":1893925243,"sampling_rate":null,"sensor":{"pin":"1","sensor_type":{"name":"SDS011","id":14,"manufacturer":"Nova Fitness"},"id":4440}},{"location":{"longitude":"13.442","altitude":"39.9","id":2233,"exact_location":0,"country":"DE","latitude":"52.518","indoor":0},"sensordatavalues":[{"value":"2266.67","value_type":"P1","id":4086502956},{"value":"999.90","value_type":"P2","id":4086502959}],"timestamp":"2020-09-17 05:01:52","id":1893902774,"sampling_rate":null,"sensor":{"pin":"1","sensor_type":{"name":"SDS011","id":14,"manufacturer":"Nova Fitness"},"id":4440}}]
Min-/Max-Temp -> Times?
Posted: Thu Sep 17, 2020 11:06 am
by xray77
Hello, Brian,
Would it perhaps be possible to display the times of the daily min/max temperatures in a future version? Maybe in brackets behind the temperature value? Should still fit in from the place in the template, it already works with the Max wind... The variables are still included in the API, I've seen...
27 [th0temp-dmaxtime:--]
29 [th0temp-dmintime:--]
The "Kts"-Bracket works fine now!
Best regards
Mike
Posted: Thu Sep 17, 2020 11:32 am
by weatherist34
good morning it won't fit with the wind only showing max time it is fine , if temperature max / min time thats two extra values according to end user format hour minutes or hour minutes seconds or 24 hour + seconds . we also have to consider non metric values when temp goes above 100F which pushes the area over the stand width.
I tried many months ago but it gets really congested in a small area and totally unbalances things in terms of design layout , only area may be possible is almanac screen .
please don't misunderstand but there are sometimes why I don't go for all data display because it becomes very very messy and congested sometimes its about finding a suitable useable GUI balance not quantity.
I still don't think the KTS is right I may look at it again over the weekend , im also not seeing the new AIR QUALITY PM10 from Davis is correct but I won't be able to fully resolve that until my unit arrives which was despatched yesterday but still I will have 4 week delivery turnaround due to local import/customs workplace restrictions in place..Brian
Posted: Thu Sep 17, 2020 12:43 pm
by xray77
Hello, Brian,
Everything is OK, your reasoning sounds plausible, it was just an idea on my part.
I don't have the overview of what would have to be taken into account to make it fit in every presentation...
The Kts-Bar looks good, Seems so that it's rounding to the next higher/lower value but is ok for me.
I haven't the new Air Quality-Sensor from Davis, my wife hasn't released the money for it yet, maybe next year.
best regards,
Mike
Posted: Thu Sep 17, 2020 1:14 pm
by weatherist34
ha same problem here so choosing the right moment and mood like taking her out for a surprise meal normally brings a calmer response as opposed to “not another gadget with wires ,why dont you just look out the window“ is a common response..
