CWOP station not showing on GRLevel3 with meteohub upload
miraculon
Post by miraculon »
I submitted a support ticket to AllisonHouse, but I thought that I would post this problem here.
I have GRLevel3 and use the CWOP placefile. Recently, my own station CW4114 has disappeared from the map. It is not in the placefile. Apparently, something has gone wrong with the feed. My data on CWOP appears OK.
Other CWOP stations are showing OK, this problem is unique to my CW4114 ID.
I temporarily switched the CWOP upload to my meteobridge, but that didn't help the issue. It was still missing from the placefile/map.
I looked at the meteohub log file and there are some errors appearing:
2014.10.29 06:37:26 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 06:42:30 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 06:47:33 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 06:47:36 meteohub-rpi: weathernet: APRS - timeout: error socket open (1): ,
2014.10.29 06:52:24 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 06:57:33 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 06:57:44 meteohub-rpi: weathernet: APRS - timeout: error socket open (1): ,
2014.10.29 07:02:25 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:07:41 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:07:52 meteohub-rpi: weathernet: APRS - timeout: error socket open (1): ,
2014.10.29 07:12:24 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:17:27 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:22:23 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:27:22 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:32:25 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:37:30 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:42:34 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:47:24 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:52:33 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 07:57:22 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:02:32 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:07:32 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:12:36 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:12:49 meteohub-rpi: weathernet: APRS - timeout: error socket open (1): ,
2014.10.29 08:17:29 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:22:23 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:27:24 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:32:28 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:37:33 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.29 08:37:43 meteohub-rpi: weathernet: APRS - timeout: error socket open (1): ,
Any suggestions on how to remedy this? As I said, the data appearing on CWOP itself is OK:
Last report from CW4114 received 21 seconds ago
Wind from 265 degrees @ 5.0 MPH Gusts to 10.0 MPH Temp 42F Humidity 93% Dewpoint 40F Rain last 24 hours 0.03 inches Pressure 1009.7 mb
Here is the raw output. I am running meteohub 5.0:
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291152z4525.05N/08348.65W_251/004g011t042r001p003P003b10090h94L000eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291157z4525.05N/08348.65W_247/004g011t042r001p003P003b10091h94L000eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291202z4525.05N/08348.65W_279/005g011t042r001p003P003b10091h94L000eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291207z4525.05N/08348.65W_256/005g011t042r001p003P003b10092h94L000eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291212z4525.05N/08348.65W_270/005g011t042r001p003P003b10092h94L000eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291217z4525.05N/08348.65W_241/004g011t042r001p003P003b10094h94L000eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291222z4525.05N/08348.65W_245/004g010t042r000p003P003b10094h94L005eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291227z4525.05N/08348.65W_262/005g010t042r000p003P003b10094h94L009eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291232z4525.05N/08348.65W_261/006g010t042r000p003P003b10095h94L009eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291237z4525.05N/08348.65W_266/005g010t042r000p003P003b10096h94L011eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291242z4525.05N/08348.65W_253/004g010t042r000p003P003b10097h93L012eMH50
CW4114>APRS,TCPXX*,qAX,CWOP-2:@291247z4525.05N/08348.65W_265/005g010t042r000p003P003b10097h93L014eMH50
Greg
miraculon
Re: CWOP station not showing on GRLevel3 with meteohub uploa
Post by miraculon »
It is working again. AllisonHouse said that the CWOP feed is unreliable.
I am still seeing socket errors in the Meteohub log however, even though the data is getting through.
2014.10.30 08:41:07 log file cleared by user
2014.10.30 08:42:36 meteohub-rpi: weathernet: APRS: error socket open (1): ,
2014.10.30 08:42:41 meteohub-rpi: weathernet: APRS - timeout: error socket open (1): ,
Greg
