Meteosticks newest firmware 2.0 supports reading RF data from Ambient Weather Observer WS1000 aka Fine Offset HP 1000/1003. Meteobridge provides this as a new weather station on "select station " tab. Support for Meteohub is still in the works. Mixed operation of Vantage and WS1000 is not supported, you have to decide to which protocol to listen, when starting Meteostick operation.
Combination of Meteobridge/Meteostick and WS1000 sensor unit can be a cost effective setup, where no console display is needed. WS1000 sensor unit provides:
- windspeed, winddir, gustspeed
- raintotal
- outdoor temperature, humidity
- solar radiation, uv index
Pressure is provided by the Meteostick.
- ws1000.png (38.18 KiB) Viewed 15059 times
