Meteobridge 2.4 (5304) Bug **no bug**
LAWx
Post by LAWx »
When I correct daily rain total in my Davis VP2 console it is not reflected in Meteobridge live data unless the correction is positive. If the correction is negative Meteobridge is not updated. If I enter two corrections in the console, like -0.05 in the console and then later undo that correction by entering a +0.05 correction, Meteobridge adds 0.05 to the original daily, monthly, and yearly rain totals without ever applying the negative correction - making the totals 0.05 too high.
Re: Meteobridge 2.4 (5304) Bug **no bug**
This is not a bug, it is expected behavior. Meteobridge does not handle manual rain total manipulations you do with the weather station console. Therefore, you also have to manually adjust rain totals in Meteobridge (which can be done on live data page).
LAWx
Post by LAWx »
It does appear to handle positive manipulations, though. It can cause some confusion when some corrections are applied and others are not.
