I recently purchased the TP Link Mr3020 so I can post my weather data to a number of sites. I am running the weatherlink Ip data logger on my Vantage Pro 2 to the MR3020. From here I wireless connect to my home router.
All is running well execept the connection between the Ip datalogger and the MR 3020 sometimes decides to stop. If I power reset the MR3020 the datalogger communicates again. I can tell when the connection has dropped when the LED on the data logger stops flickering.
I am very new to this and its a steep learning curve. Any help would be greatly appreciated.
VP2 and TL-mr3020
RottenMutt
- Fresh Boarder
Re: VP2 and TL-mr3020
are you using the usb hub?
The MB allows a window for the WLIP to talk to say a PC or upload to WeatherLink.com at set intervals otherwise the MB has priority to sensor data.
On the Select Station tab, what do you have the WL Upload time interval set to? 1 min, 5 min 10 min or NO upload?
