Missing values day1 and last60 **solved**
wouterk
Post by wouterk »
Since a couple of days I am missing values of some variables in the output of meteohub. It seems the variables with "day1........" and "last60......." are missing.
I am using versie 5.0d of the meteohub application. I have checked the logs and there are no messages of "bad data" or anything else which looks not ok.
I hope someone of you will have an idea what could be the cause of this.
In the attachment I have the output of the ipaddress-meteohubpc:5558 of the meteohub which is running on a Alix.1D:
actual_system_version_text 5.0d
actual_system_version_num 50
actual_system_build_num 7217
actual_system_platform_text ALIX.1D_(500_MHz)
actual_system_language_text Dutch
actual_system_temp_unit c
actual_system_hum_unit rel
actual_system_press_unit hpa
actual_system_wind_unit bft
actual_system_rain_unit mm
actual_utcdate 20150103182829
actual_utcdate2 03.01.2015 18:28:29
actual_date0_puredate_utc 03.01.2015
actual_date0_time_utc 18:28:29
actual_date0_year_utc 2015
actual_date0_month_utc 01
actual_date0_day_utc 03
actual_date0_dayofweek_utc 6
actual_date0_hour_utc 18
actual_date0_min_utc 28
actual_date0_sec_utc 29
actual_localdate 20150103192829
Thanks it advance
output.zip
(9.7 KiB) Downloaded 318 times
Re: Missing values day1 and last60
BUMP
Meteohub only generates actual_ values, none of the day1_ month_ and so on are changed with the new values..
This is one of the first users of my template.
So I bump this as the website is totaly broken by all the missing day1 values.
http://www.weerstation-nijbroek.nl/weat ... x.php?p=10
Is there anyone with even the faintest idea how this can happen?
Look at your own meteohub-ip:5558 output and compare with these lines;
alltime_data1_valuedeltasum_num 7545052200.00
alltime_data1_valuedeltasum_int -2147483648
day1_utcdate 20150103182501
day1_localdate 20150103192501
hour1_utcdate 20150103182501
hour1_localdate 20150103192501
last15m_utcdate 20150103182501
last15m_localdate 20150103192501
last24h_utcdate 20150103182501
last24h_localdate 20150103192501
last60m_utcdate 20150103182501
last60m_localdate 20150103192501
month1_utcdate 20150103171511
month1_localdate 20150103181511
month1_wind1_maxspeeddir_deg 202.5
month1_wind1_maxspeeddir_de SSW
Normaly there are hundreds of lines between the last alltime and the first month line.
All the other time-slots have all sensors are present, but not for day1 - hour1- and so on.
And another clue: None of the calculated month_ alltime- and so on values are changed with the new actual_ values.
It seems Meteohub is not using the actual_ values AT ALL
Were do we have to look?
There seems to be no errors in the logs?
HELP
It took some (better much) testing and reinstalling. We discovered that removing all past data files resolved the problem.
Only after a logon by Boris the reason was found, these are his words:
I found the problem. When you look at the first data sets, you will see that somehow data of 5th January is at the beginningof the file.
These blocks all following data from being read, as Meteohub inspects linear increasing time stamps and no jumping forth and back.
I deleted those lines and did start recomputation. When done,all should look fine again.
No idea, how this happened.
And indeed all data is now appearing as it should.
This problem started on/just after the first day of the year. Maybe a backup/restore went wrong.
As every day the data for the first few measurements was written at the beginning of the file, we will check if the problem comes back next month Feb.1 or Jan.1 next year.
And again:
Big thanks to Boris.
YJB
Post by YJB »
I remember running into this kind of issue a long time ago (data out of order in the raw files). With a simple sort the issue was addressed.
wouterk
Post by wouterk »
Thanks everyone for helping me out.
Everything is working again like it should.
