Pocket PWS
sv2bzq
Pocket PWS
Post by sv2bzq »
Please tell me if we have the .XML file for Pocket PWS http://android.teszdesign.hu/ https://play.google.com/store/apps/deta ... pocket.pws
and if not . if you can help .
Thanks for the time
George .
Napajedlaci.cz
Re: Pocket PWS
Post by Napajedlaci.cz »
I have this android application done by HTML template into which I meteohub been enriching values automatically. Template, then send over a minute to FTP, where using URL loading data into the application.
<?xml version="1.0" encoding="UTF-8" ?>
<maintag>
<!--MISC-->
<misc><misc data="station_location">Napajedláci.cz</misc></misc>
<!--STATION DATA-->
<realtime><data realtime="station_date">[actual_date0_puredate_local]</data></realtime>
<realtime><data realtime="station_time">[actual_date0_time_local]</data></realtime>
<realtime><data realtime="sunrise">[actual_sunrise_standard_local]</data></realtime>
<realtime><data realtime="sunset">[actual_sunset_standard_local]</data></realtime>
<realtime><data realtime="moonrise">[actual_moonrise_standard_local]</data></realtime>
<realtime><data realtime="moonset">[actual_moonset_standard_local]</data></realtime>
<!--TEMPERATURE-->
<realtime><data realtime="temp">[actual_th0_temp_c]</data></realtime>
<realtime><data realtime="high_temp">[day1_th0_tempmax_c]</data></realtime>
<realtime><data realtime="low_temp">[day1_th0_tempmin_c]</data></realtime>
<realtime><data realtime="heatindex">[actual_th0_heatindex_c]</data></realtime>
<realtime><data realtime="high_heatindex">[day1_th0_heatindexmax_c]</data></realtime>
<!--HUMIDITY-->
<realtime><data realtime="hum">[actual_th0_hum_rel]</data></realtime>
<realtime><data realtime="high_hum">[day1_th0_dewmax_c]</data></realtime>
<realtime><data realtime="low_hum">[day1_th0_dewmin_c]</data></realtime>
<!--WIND-->
<realtime><data realtime="winddir" misc="imgwinddir">[actual_wind0_dir_deg]</data></realtime>
<realtime><data realtime="windspeed">[actual_wind0_gustspeed_ms]</data></realtime>
<realtime><data realtime="high_windspeed">[day1_wind0_gustspeedmax_ms]</data></realtime>
<realtime><data realtime="windchill">[actual_wind0_chill_c]</data></realtime>
<realtime><data realtime="low_windchill">[day1_wind0_chillmin_c]</data></realtime>
<!--DEWPOINT-->
<realtime><data realtime="dew">[actual_th0_dew_c]</data></realtime>
<realtime><data realtime="high_dew">[day1_th0_dewmax_c]</data></realtime>
<realtime><data realtime="low_dew">[day1_th0_dewmin_c]</data></realtime>
<!--BAROMETER-->
<realtime><data realtime="barometer">[actual_thb0_sealevel_hpa]</data></realtime>
<realtime><data realtime="high_barometer">[day1_thb0_sealevelmax_hpa]</data></realtime>
<realtime><data realtime="low_barometer">[day1_thb0_sealevelmin_hpa]</data></realtime>
<!--RAIN-->
<realtime><data realtime="todaysrain">[day1_rain0_total_mm]</data></realtime>
<realtime><data realtime="rain_rate">[day1_rain0_rate_mm]</data></realtime>
<realtime><data realtime="high_rain_rate">[day1_rain0_ratemax_mm]</data></realtime>
<!--UNITS-->
<realtime><data units="windunit">m/s</data></realtime>
<realtime><data units="rainunit">mm</data></realtime>
<realtime><data units="rateunit">mm</data></realtime>
<realtime><data units="barunit">hPa</data></realtime>
<realtime><data units="tempunit">°C</data></realtime>
<realtime><data units="humunit">%</data></realtime>
</maintag>
Napajedlaci.cz is very good weather station in Czech republic neer town Zlin.
sv2bzq
Re: Pocket PWS
Post by sv2bzq »
ok Thanks work fine .
But only the
not write nothing .
Any idea ?
George .
Re: Pocket PWS
There are days where there is no moon rise or moon set.
sv2bzq
Re: Pocket PWS
Post by sv2bzq »
ok .thanks work fine now ....
George.
