Wunderground and zero temperature **solved**
steve-invest
Post by steve-invest »
When the temperature hits 0 F, Wunderground interprets that as no reading, and eventually says that I am not reporting. (I am, and wunderground dutifully records all the wind readings.) I have version 2.4 of metobridge, which sounded like it was a fix for this very problem, but it didn't fix it.
Re: Wunderground and zero temperature
This has just been fixed. Please reboot your Meteobridge.
steve-invest
I was hoping that I wouldn't be able to test this because the temperature stayed above zero. No such luck. It worked fine last night at below zero. Thank you very much for your prompt response.
