Acurite 3 in 1 **solved**
jswnhart
Post by jswnhart »
The Acurite 3 in 1 sensor is not listed in the documentation. I am seeing the temperature and humidity, but not the wind speed, in the live data. Is there a plan to support this? Thanks.
jswnhart
Re: Acurite 3 in 1
Post by jswnhart »
I just turned on the rain guage and this does not show up in the live data either.
Re: Acurite 3 in 1
Are you using the Acurite Bridge? or USB version?
jswnhart
Re: Acurite 3 in 1
Post by jswnhart »
Aculink bridge + 3 in 1 (temp, humidity, wind speed) + tower (temp, humidity) + rain gauge.
Re: Acurite 3 in 1
Can you please give me access as explained below
and send the link to "info(at)meteobridge.com"?
viewtopic.php?f=57&t=9885
Re: Acurite 3 in 1
I was able to login and test an update. As a result Meteobridge now also supports the wind-direction-less 3in1 sensors. :mrgreen:
jswnhart
Re: Acurite 3 in 1 **solved**
Post by jswnhart »
Station is up on WU and performing exactly as expected.
Thank you for such great support.
jswnhart
Post by jswnhart »
I get a fixed wind direction of N (0') reported by WU. Is it possible to disable/eliminate this parameter when uploading data?
From WunderMap WIki PWS Upload Protocol
winddir - [0-360 instantaneous wind direction]
I tried posting in WXforum and didn't get a response.
no, it does not have that feature.
