SFTP on
Chill
SFTP on
Post by Chill »
Hi all,
can anyone tell me if SFTP is installed/enabled by default in any meteohub under NSLU2 (v4.9 and higher)?
If so, if it's activated how can I connect to it?
I'm trying ang getting this message: "Cannot initialize SFTP protocol. Is the host running a SFTP server?"
If not installed, could I install it? How?
I read: "If you want to use SFTP, then you need to install also the package openssh-sftp-server (At least I need it -thx1011). On OpenSlug 2.7Beta even after installing package openssh, you need this one. Then you can use, for example on windows side, the WinSCP freeware program, ou also, the integrated SFTP client into OpenSSH windows client. This will allow file transfer using SSH for remote access without exposing your Samba shares."
Is this the way?
TIA,
Chill
Re: SFTP on
not supported.
Chill
Re: SFTP on
Post by Chill »
Hi Boris,
Thanks for your answer...
Still, was it supported time ago?
wfpost wrote:If you´re using Filezilla as FTP Client
you can access your meteohub in simly selecting SFTP :wink:
It comes to my memory I did connect through SFTP. Am I confused?
TIA
