PROBLEM DIR 505
S-O-C
PROBLEM DIR 505
Post by S-O-C »
HELLO
I install on a dlink DIR 505 Meteohub to a test
I'm very happy
the problem is that would change hardwar
how to find the configuration with the firmwar dlink DIR 505
I can not install a dlink firmwar
es that possible
or the device is lock with Meteohub forever
hALLO
installiere ich auf einem dlink DIR 505 Meteohub mit einem Test
Ich bin sehr glücklich
das Problem ist, das wäre hardwar ändern
wie Sie die Konfiguration mit dem firmwar dlink DIR 505 finden
Ich kann eine dlink firmwar nicht installieren
es möglich, dass die
oder das Gerät immer sicher mit Meteohub
BONJOUR
j'ai installer sur un DIR 505 dlink Meteohub pour faire un essais
je suis très content
le problème est que voudrais changer hardwar
comment retrouver la configuration avec le firmwar dlink DIR 505
je n'arrive pas a installer le firmwar dlink
es ce possible
ou l'appareil est bloquer avec meteohub pour toujours
Re: PROBLEM DIR 505
By browsing to "http://ip-of-your-meteobridge//cgi-bin/fwupdate.cgi" you can upload openwrt firmware.
Installing original DIR-505 firmware should also work, but I didn't test this.
But come on, who really wants to go back ;-) ...and the devices are really cheap.
S-O-C
Re: PROBLEM DIR 505
Post by S-O-C »
thank you for your answer
the issue is not that the device is expensive or cheap :)
I just want to find the original of this device status :D
and change for a new device
I tried your method with the latest firmware dlink it does not work :(
Re: PROBLEM DIR 505
DIR-505 has a special mode that presents a web interface during boot then reset button is pressed during power up.
This should allow you to install D-Link firmware. But it just works with a very few browsers etc.
When you google a bit around "D-Link DIR-505 emergency flashing" you will find the recipe below:
1. Plug the Ethernet cable that connects your computer, that was plugged into one of the LAN ports,
2. Setup your PC with static IP - ex: 192.168.0.2 (different from 192.168.0.1)
3. Make sure the PC has the new firmware
4. Unplug the power
5. Hold the reset button for 3~5 seconds and re plug the power WITHOUT RELEASING THE RESET BUTTON.
6.Open a web browser to 192.168.0.1 and then you should see EMERGENCY FLASHING page then click browse/upload locate the file and click UPLOAD FIRMWARE NOW
7. You should see a SUCCSESS page, If you don’t then re do steps 2-6
more to read... http://forums.dlink.com/index.php?topic=44909.0
