1 sensor not appearing in the sensor tab **solved**
flashy
Post by flashy »
Just got the meteohub working with my oregon wmr200.
all sensors are working fine except for the wind sensor which does not appear in the sensor tab.
After Looking at the meteohub log file i can see the following message:Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
What does it mean ?, any idea to fix this and have my wind sensor available in meteohub?
Thanks in advance for your help
Re: 1 sensor not appearing in the sensor tab
Please assign the primary outdoor hum sensor an ID, first.
Having done that, wind sensor is able to compute wind chill
and wind data will also appear on sensor page.
Please also check on "weather station" page that an existing TH sensor is
specified to be used for windchill computation.
flashy
Post by flashy »
Works fine now,
Thé Wind chill calculation was not set properly in the weather station tab
