meteobridge not updating WU
ngiovas
Post by ngiovas »
I'm still in my evaluation period of Meteobridge and trying to work out the kinks, but it appears that I have run into another issue.
I had the system up and running yesterday and it appeared to be updating realtime with no issues all afternoon. Late last night I noticed that the WU site said the data was updated one minute earlier, but the temp and wind speed were way off. I checked the weather station display (Acurite) and the Meteobridge live data tab and both were up to date. It also said data was being sent to WU successfully.
On WU it says an update was received within the past few minutes (not seconds), but the data never changes. It also no longer is displaying my station on the map. I have to click on my personal weather station to view it.
Does anyone have any suggestions? My meteobridge is obviously getting a wireless signal since I can access it from another computer. And it is getting realtime data from the station according to the live data tab. I just need to figure out why it isn't displaying on the site.
Nick
SANdood
Re: meteobridge not updating WU
Post by SANdood »
The first thing I would try is rebooting your MeteoBridge.
2nd - are you using the new repeater function to allow another app to connect to the MB as Davis client? Try shutting down that application and rebooting again...
ngiovas
Post by ngiovas »
I tried rebooting twice (once through the web interface and once by unplugging the router). It did not resolve the issue. About an hour later it started reporting again (every 30 seconds as configured) and the station appeared on the map again.
It has been about 2 hours since it came back up and I just noticed that it is down again. The station is no longer appearing on the map and the data is way off and not changing.
I am not familiar with the repeater feature and don't believe I would have turned this on (where can I check this).
When it was down overnight, it never sent the message that the station was offline for more than 2 hours, so it must be getting a signal every once in a while. Looking at the graphs on the site, it appears that there is a report every once in a while and then suddenly the data jumps back up to the old values.
Are you using the mandatory USB hub?
ngiovas
Post by ngiovas »
yes, I am using this hub:
http://www.amazon.com/gp/product/B00GU8 ... UTF8&psc=1
I don't think that is the issue since when I view the "live data" tab on the router through the web interface it is showing the correct data. It is also showing that it successfully updated Weather Underground (green checkmark and current time stamp).
May be I should have a look myself. This link explains how to setup remote access.
viewtopic.php?f=57&t=9885
Please send link and password to "info(at)meteobridge.com".
First of all, I don't want to bash WU, which is a great free service!
But it started about a year ago that the webcam upload service of
WU was showing strange behavior on some users but works fine for others. In the end
there came up that much error reports from various users of various SW solutions,
that it became clear that WU is having some issues, that randomly appear and vanish.
Since a few months, the weather data uploading also starts to show mysteries for
some users. Can be some side effects from their new display options, but it is going
a bit backwards on reliability imho.
However, I would like to check myself to rule out Meteobridge issues.
