Cannot update to 2.5 after choosing version 2.4 **solved**
nicolashebert
Post by nicolashebert »
Hi I cannot update to 2.5 after the last update after clicking on version control to 2.4.
when I click on save the version control keep saying 2.4
wsnoordbergum
Re: Cannot update to 2.5 after choosing version 2.4
Post by wsnoordbergum »
Hi.
I've had some trouble going back to version 2.2
Version 2.5 was no succes for me.
Now that has been fixed by admin, there was a bug.
Have you tried on selecting newest on the version selector?
There is no need to save first, just click newest and then click reboot.
It should than be version 2.5 which is the latest version.
I also had a message saying Open pipe Dev/ meteobridge no such device etc......
Maybe there is a bug....
Good luck wsnoordbergum.
When you reboot, the problem that you are stuck to 2.4 should be solved.
nicolashebert
It's working now.
do I need to click on save when I when to have version contrel.
Thanks Bye
no, it saves itself on any change. But the effect is only applied on a new reboot (as expected).
