PI B+ install MH
WSParkstad
PI B+ install MH
Post by WSParkstad »
I wil install version 5.0 on a Raspberry B+.
Mus i have a usb connection, or can i install Meteohub and config meteohub with Weatherlink IP?
With best regards,
Marcel.
WSParkstad
Re: PI B+ install MH
Little information against which I run, did exactly as documented, but the lights of the Ethernet port either, whereas if I NOOBS it works then put the Ethernet port.
During the install I saw at eth0 or an eror message.
The raspberry that I want to install a B + version, no version 2, I know that does not work.
Have also read that I have to sign anything and just have to approach via web Meteohub but without eth0 me will never go to work.
