Lost MB connection to Davis IP loggers today
ghasdorff
Post by ghasdorff »
Today two of my nine MeteoBridge stations stopped reading their Davis consoles after the daily reboot (and version upgrade). The two stations where the MeteoBridge stopped reading the console data both have Davis IP loggers, all the other seven stations with usb and serial loggers are still working great.
Here is what I see in the MeteoBridge message window of one of the stations that uses an IP logger:
logger (03.02.2015 15:49:02): station 0 (Vantage), error connect socket 172.17.10.229: port 5500: Connection refused
logger (03.02.2015 15:49:33): station 0 (Vantage), error connect socket 172.17.10.229: port 5500: Connection refused
logger (03.02.2015 15:50:02): station 0 (Vantage), error connect socket 172.17.10.229: port 5500: Connection refused
logger (03.02.2015 15:50:32): station 0 (Vantage), error connect socket 172.17.10.229: port 5500: Connection refused
logger (03.02.2015 15:51:02): station 0 (Vantage), error connect socket 172.17.10.229: port 5500: Connection refused
logger (03.02.2015 15:51:32): station 0 (Vantage), error connect socket 172.17.10.229: port 5500: Connection refused
logger (03.02.2015 15:52:02): station 0 (Vantage), error connect socket 172.17.10.229: port 5500: Connection refused
In both cases the Davis IP loggers are still doing their own reporting to Davis WeatherLink. I can open a browser to the IP logger itself and see the configuration screen of the logger. Rebooting the MeteoBridge didn't change the symptoms. If you would like to connect I can send you the login info for one of these two stations. Unfortunately the other station is in a facility that blocks the VPN tunnel feature from their internal network.
Thank you very much.
Glenn
Re: Lost MB connection to Davis IP loggers today
sending a link to login to "info(at)meteobridge.com" will help much to get this quickly solved.
P.S.: Does it work, when you specify port ":22222" behind the IPs?
