This Update fixes three bugs introduced with 2.3b
o Fixes the bug of resetting workgroup to \"HOME\" after having installed an update.
o Fixes a bug that prevents Meteohub to generate graphs according to a given time schedule for upload.
o Fixes a bug that occurs when asking meteograph.cgi for sensor values. This bug causes the dashboard not to show values when the dashboard directly communicates with meteograph.cgi and does not take data uploaded via FTP.
Meteohub Bug Fix Update 2.3c
- Junior Boarder
Re:Meteohub Bug Fix Update 2.3c
the update was succesfull. only the sealevel option isn't working yet.
my wmr200 console shows 1018 at the moment (which is the sealevel pressure after setting the height in the console). meteohub still displays 1020 (local pressure).
setting the sealevel to a height of 20m gives me a local pressure of 1020 and a sealevel pressure of 1022 (which is correct).
setting a negative height of -20m gives me 1020 for both the local and sealevel pressure. nothing happens :(
(btw: the calculation methode is set on 'compute based on weather station's height')
what about the workaround to set station heigt in meteohub to 20m and to reduce the pressure by 2 mb with the new sensor calibration function. Both, sealevel and local pressure should be affected by this.
well it is just a workaround, but please give it a try as this also is a test for the new calibration function in meteohub.
however, I will have a look, why negative altitude is not working as expected.
- Junior Boarder
that works! but now sea-level and local pressure resemble sea-pressure :P
i found another bug updating from 2.3 to 2.3c
The port set before updating was 1212 after 80
