"Invalid peer certificate" Error v5.0g iConnect **solved**
AlaskaWX
Post by AlaskaWX »
Just tried the 5.0g meteohub update on iConnect platform and am getting an
Mail send failed: Invalid peer certificate (error 20)#0 (null)#xxx@yyyy.com: 0 (null)
error when setting up and testing TLS push service to gmail.com. Any fixes planned for this condition?
FYI: meteohub version 4.9y was the last version that didn't have this problem! :?
Davis VP2 with IIS and Leaf/Soil + numerous user defined plugin weather stations
Re: "Invalid peer certificate" Error on version 5.0g in iCon
Could you please give me remote access to your system on port 22 and 7777?
I moved from esmtp to msmtp on the x86 and RPI platforms to solve this issue.
Although the iConnect is no longer a fully supported platform, I would like to fix this
also for iConnect. At least I would like to try.
AlaskaWX
Post by AlaskaWX »
Boris,
I can start-up the reverse SSH tunnel to give you access to a second "test" system I have running in demo mode that you can play with for troubleshooting purposes.
AlaskaWX
Post by AlaskaWX »
Thanks Boris. The 5.0i update solved the problem and is working great now!
