Hi;
I just got a new Portable 3G/4G wireless N Router (TL-MR3020), I connected it as the Standard AP Mode, However, i couldnot find the wireless network ( SSID) named TP-LINK_POCKET_3020_* . I also tried the WISP Client Router Mode, but still can not find the wireless network. I am using MAC OS.
Can anyone help?
many thanks
jessie
Can not find the wireless network
Re: Can not find the wireless network
Did you flash Meteobridge to it, or are you still in the steps before doing this?
NO, i didn't flash Meteobrige, still in the very first step. My understanding is that once I connect the TL-MR3020 to the Ethernet port and power source, then I should be able to find the wireless network ( SSID) named TP-LINK_POCKET_3020_*, then do the configurations.. but still can not find the wireless network
TP-Link should explain how to access their products on the colaterals of the package.
On "getting started" page of "www.meteobridge.com" it is also explained how to connect to it
with the help of an ethernet cable. I never heard of connecting to it first hand via WiFi,
so I cannot comment that route (if it exists at all).
thanks for your reply.
I am sure i have connected it correctly, following the user manual.
however, all the installation and configuration is based upon successfully connected to the router via a web browser. this is where i am stuck.
so could you think of any reasons cause this? could it be a hardware issue?
- Fresh Boarder
i have got the same problem it is working fine on a cabled connection but can't get a wireless connection i have tried every thing so just left it on cabled for now
