Davis Vantage Vue with DIR-505 and homebrew interface
pinswede
Post by pinswede »
Hi, I have just started up Meteohub (trial) on a D-link DIR-505, and a homebrew Davis Vantage Vue interface
made up of a TTL -> USB converter (Rapsberry type) and also an attached PIC from Torkel. My Davis have the dreaded FW 3.0.... :roll:
Tx and Rx is of course attached to pin 5 & 6 of the Davis, I have even reversed them as I wasn't sure about which was Tx & Rx on the Rasperry converter... :oops:
Here's the log from Meteorhub, it seems to repeat itself, I have tried http://www.wunderground.com, but the data I sent seems to be very strange, and now wunderground says "This PWS is not reporting"....
logger (04.04.2015 13:11:22): connect station 0 (Vantage via USB serial).
logger (04.04.2015 13:11:22): wakeup sent.
logger (04.04.2015 13:11:22): internal logger activated.
logger (04.04.2015 13:11:22): syncing.
logger (04.04.2015 13:11:30): gettime request sent.
logger (04.04.2015 13:11:40): gettime request sent.
logger (04.04.2015 13:11:50): gettime request sent.
logger (04.04.2015 13:12:30): disconnect station 0 (Vantage): timeout
logger (04.04.2015 13:12:32): connect station 0 (Vantage via USB serial).
logger (04.04.2015 13:12:32): wakeup sent.
logger (04.04.2015 13:12:32): internal logger activated.
logger (04.04.2015 13:12:32): syncing.
logger (04.04.2015 13:12:40): gettime request sent.
logger (04.04.2015 13:12:50): gettime request sent.
logger (04.04.2015 13:13:00): gettime request sent.
logger (04.04.2015 13:13:40): disconnect station 0 (Vantage): timeout
logger (04.04.2015 13:13:42): connect station 0 (Vantage via USB serial).
logger (04.04.2015 13:13:42): wakeup sent.
logger (04.04.2015 13:13:42): internal logger activated.
logger (04.04.2015 13:13:42): syncing.
logger (04.04.2015 13:13:50): gettime request sent.
logger (04.04.2015 13:14:00): gettime request sent.
logger (04.04.2015 13:14:10): gettime request sent.
When I use RealTerm @ 19200 8N1 COM5 all I get is OK when sending commands like TEST, VER etc....
I have also tried with a USB 2.0 hub between the USB converter and the DIR-505... , but no difference.
Anyone? :D
pinswede
Re: Davis Vantage Vue with DIR-505 and homebrew interface
Post by pinswede »
Oops, newbie alert.. :D I just realized I posted the above in the wrong forum...I apologize... :oops: pls, admin move to correct forum, thanks.
done
