Usb not detected
RHead
Usb not detected
Post by RHead »
Hi.
I just changed my x86 server. Every else works fine but usb connection to Nexus on Vmware.
I have installed os windows 8.1 and running vmware workstation on it.
On Windows 8.1 with Weatherdisplay, Wswin works fine usb, but vmware meteohub don't work.
logger (17.04.2015 13:14:11): child process received timeout signal (14).
logger (17.04.2015 13:14:11): disconnect station 0 (TE-923): exit
logger (17.04.2015 13:14:12): data logger stopped.
logger (17.04.2015 13:14:12): data logger (version 5.0i, build 7249) started.
logger (17.04.2015 13:14:13): connect station 0 (TE-923 via USB HID).
Re: Usb not detected
Your VM environment needs to be told to hand over a certain USB connection to the Meteohub VM.
Please get familiar with your VM setup. This is nothing Meteohub specific.
RHead
Post by RHead »
Problem was solved. When i did upgrade vmware image to version that support 11. I didn't work. Atleast for version 8 works fine.
