Aculink down
rgarza28
Aculink down
Post by rgarza28 »
I've been running Meteobridge for sometime now with the Aculink bridge. Since last Friday the data has stopped getting out. The Live Data Tab shows "No Weather network traffic". My router no longer see the bridge and the System log shows it timing out. I've powered cycled the bridge and the D-Link unit. Here is the System Log for you to check out:
wnetd (27.04.2015 18:54:40): process started.
test5m (27.04.2015 18:54:43): logger stalled, will be restarted now
logger (27.04.2015 18:54:43): Historical data loaded (15 records).
logger (27.04.2015 18:54:43): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 18:54:44): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 19:05:14): child process received timeout signal (14).
logger (27.04.2015 19:05:14): disconnect station 0 (AcuLink): exit
logger (27.04.2015 19:05:14): data logger stopped.
logger (27.04.2015 19:05:14): Historical data loaded (15 records).
logger (27.04.2015 19:05:14): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 19:05:15): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 19:15:45): child process received timeout signal (14).
logger (27.04.2015 19:15:45): disconnect station 0 (AcuLink): exit
logger (27.04.2015 19:15:45): data logger stopped.
logger (27.04.2015 19:15:45): Historical data loaded (15 records).
logger (27.04.2015 19:15:45): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 19:15:46): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 19:26:16): child process received timeout signal (14).
logger (27.04.2015 19:26:16): disconnect station 0 (AcuLink): exit
logger (27.04.2015 19:26:16): data logger stopped.
logger (27.04.2015 19:26:16): Historical data loaded (15 records).
logger (27.04.2015 19:26:16): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 19:26:17): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 19:36:47): child process received timeout signal (14).
logger (27.04.2015 19:36:47): disconnect station 0 (AcuLink): exit
logger (27.04.2015 19:36:47): data logger stopped.
logger (27.04.2015 19:36:47): Historical data loaded (15 records).
logger (27.04.2015 19:36:47): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 19:36:48): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 19:47:18): child process received timeout signal (14).
logger (27.04.2015 19:47:18): disconnect station 0 (AcuLink): exit
logger (27.04.2015 19:47:18): data logger stopped.
logger (27.04.2015 19:47:18): Historical data loaded (15 records).
logger (27.04.2015 19:47:18): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 19:47:19): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 19:57:49): child process received timeout signal (14).
logger (27.04.2015 19:57:49): disconnect station 0 (AcuLink): exit
logger (27.04.2015 19:57:49): data logger stopped.
logger (27.04.2015 19:57:49): Historical data loaded (15 records).
logger (27.04.2015 19:57:49): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 19:57:49): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 20:08:19): child process received timeout signal (14).
logger (27.04.2015 20:08:20): disconnect station 0 (AcuLink): exit
logger (27.04.2015 20:08:20): data logger stopped.
logger (27.04.2015 20:08:20): Historical data loaded (15 records).
logger (27.04.2015 20:08:20): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 20:08:20): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 20:18:50): child process received timeout signal (14).
logger (27.04.2015 20:18:50): disconnect station 0 (AcuLink): exit
logger (27.04.2015 20:18:50): data logger stopped.
logger (27.04.2015 20:18:51): Historical data loaded (15 records).
logger (27.04.2015 20:18:51): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 20:18:51): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 20:29:21): child process received timeout signal (14).
logger (27.04.2015 20:29:21): disconnect station 0 (AcuLink): exit
logger (27.04.2015 20:29:21): data logger stopped.
logger (27.04.2015 20:29:21): Historical data loaded (15 records).
logger (27.04.2015 20:29:21): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 20:29:22): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 20:39:52): child process received timeout signal (14).
logger (27.04.2015 20:39:52): disconnect station 0 (AcuLink): exit
logger (27.04.2015 20:39:52): data logger stopped.
logger (27.04.2015 20:39:52): Historical data loaded (15 records).
logger (27.04.2015 20:39:52): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 20:39:53): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 20:50:23): child process received timeout signal (14).
logger (27.04.2015 20:50:23): disconnect station 0 (AcuLink): exit
logger (27.04.2015 20:50:23): data logger stopped.
logger (27.04.2015 20:50:23): Historical data loaded (15 records).
logger (27.04.2015 20:50:23): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 20:50:24): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 21:00:54): child process received timeout signal (14).
logger (27.04.2015 21:00:54): disconnect station 0 (AcuLink): exit
logger (27.04.2015 21:00:54): data logger stopped.
logger (27.04.2015 21:00:54): Historical data loaded (15 records).
logger (27.04.2015 21:00:54): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 21:00:55): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 21:11:25): child process received timeout signal (14).
logger (27.04.2015 21:11:25): disconnect station 0 (AcuLink): exit
logger (27.04.2015 21:11:25): data logger stopped.
logger (27.04.2015 21:11:25): Historical data loaded (15 records).
logger (27.04.2015 21:11:25): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 21:11:25): connect station 0 (AcuLink via USB HID).
logger (27.04.2015 21:11:36): parent process received termination signal (15).
logger (27.04.2015 21:11:36): child process received termination signal (15).
logger (27.04.2015 21:11:36): disconnect station 0 (AcuLink): wrap-up
logger (27.04.2015 21:11:36): data logger stopped.
logger (27.04.2015 21:11:37): Historical data loaded (15 records).
logger (27.04.2015 21:11:37): data logger (version 5.0i, build 6256) started.
logger (27.04.2015 21:11:38): connect station 0 (AcuLink via USB HID).
rgarza28
Re: Aculink down
Post by rgarza28 »
I unplugged the bridge and connected it directly to the route and it now picks it up. There seems to be something wrong on the D-Link 505 system.
