The console is working fine, showing all sensors.
The usb adapter is showing up on the Meteohub as /dev/ttyUSB0 and /dev/ttyMH131 in the Weather Station section.
The Meteohub "First Steps" document implies the sensor data should be coming in, but I'm not showing anything. I've tried both /dev devices via the pull-down, no change. If I unplug the console, both devices disappear from the menu, as expected.
I'm presuming I'm doing something very basic wrong. Can someone shed some light?
