Serial to USB adapters **solved**
PWS
Post by PWS »
I assume that the answer to this is 'yes', but can I just double-check:
To connect a _serial_ Weatherlink logger to MB clearly requires a serial-to-USB adapter. If the separate adapter has an FTDI chipset, can I assume that MB has the relevant driver onboard already?
Re: Serial to USB adapters
yes, Meteobridge can handle USB serial converters with FTDI, pl3203 or cp210x chipsets in it.
