Davis fct text <=> Meteostick on Meteobridge
I understand that Meteostick can not supply us with the Davis forecast code or string.
So I put a default text into my template when there is, for whatever reason, no forecast text available:
|fcstTxt|[forecast-text:Data will be reloaded in]|!
Works in all tested cases but not for a Davis => Meteostick => Meteobridge
The Meteobridge returns in this case an empty string and not the value after the :
So I get returned:
|fcstTxt||!
and I expected:
|fcstTxt|Data will be reloaded in|!
Is this correct behavior?
I vaguely remember a similar post but could not find it, sorry if it is already answered somewhere else.
Re: Davis fct text <=> Meteostick on Meteobridge
Reason is that Meteobridge does not report back "no string" but returns an empty string.
I will fix that with next update.
Ger
Post by Ger »
When can we expect this update?
