Latest Updates
baobab
Latest Updates
Post by baobab »
I am considering purchasing a Meteostick to use with my system which runs on an iConnect. Given that I cannot update the iConnect to anything more recent than Meteohub v. 4.9w (Build 1429) will the Meteostick work as intended with the iConnect?
Baobab
Re: Latest Updates
Why can't you update to 5.x?
baobab
Re: Latest Updates
Post by baobab »
The System Info screen on the user interface says that the version running on my system is 4.9w. When I click on the "Check for Updates" button on the Maintenance screen of the user interface it tells me that no update is available. I assumed that this is because iConnect is no longer being supported for updates due to hardware streamlining. Perhaps my assumption is incorrect?
Re: Latest Updates
baobab wrote:The System Info screen on the user interface says that the version running on my system is 4.9w. When I click on the "Check for Updates" button on the Maintenance screen of the user interface it tells me that no update is available. I assumed that this is because iConnect is no longer being supported for updates due to hardware streamlining. Perhaps my assumption is incorrect?
You should read:
viewtopic.php?f=14&t=9698
and
viewtopic.php?f=23&t=9704
about a one-time manual update.
After that automatic updates will work again,
