I have a TP-Link TP3040 running Meteobridge that I've been using since last November. I recently rebooted it to update the firmware to the latest version and since then, I have been unable to get the meteobridge to connect to my network wirelessly; it will only connect via Ethernet.
Nothing has changed; it was working wirelessly before but won't connect that way now.
I have rebooted it via the web interface and via pushing the reset button with a paperclip until the top LED blinks once. I have attempted to connect via DHCP and via a fixed IP address. I have checked the password. It will only connect to the network via Ethernet cable.
Any clues, tips or advice on what to do to get the Meteobridge to connect wirelessly would be most appreciated.
Can't get Meteobridge to switch from Ethernet to wireless
Re: Can't get Meteobridge to switch from Ethernet to wireles
I had the same problem in the past and the MH was not the issue. I rebooted the wireless router and the MH connected instantly. I suspect that something might have been corrupted in the AP. My network has both 2.4GHz and 5.8GHz radios and I constantly have issues with the 802.11n/g network due to extreme congestion of RF signals in my location. The 802.11ac never has any issues, but is not compatible with the MH.
