Additional temp sensors in Push notifications **solved**
viennaxmas
Post by viennaxmas »
I have one problem with push notifications:
My system has two temperature sensors, on the live data page they show up as "Outdoor temp" and "Outdoor T temp #5". Both are showing values on the "Live data" page.
So far so good.
Now I am trying to set up a push notification:
[th0temp-act.1:--]°C ==> works and shows the values of the "Outdoor temp"
[th5temp-act.1:--]°C ==> does not work and only shows "--" as results.
According to http://www.meteobridge.com/wiki/index.php/Templates I would expect that th5temp actually returns the valies of the "Outdoor T temp #5" sensor.
The log file has also shown: "temperature sensor #00168 newly registered (th5)." when I connected the sensor for the first time..
I am running:
Platform: TP-LINK TL-MR3020 (no USB hub)
RAM: 29364 kB total, 1900 kB free (93% used)
SW Version: Meteobridge 2.5 (Jun 9 2015, build 6387), FW 1.4
with an Acurite Internet Bridge.
Any idea?
Re: Additional temperature sensors in Push notifications
Looks like it is a temp only sensor (no humidity). Then "t5temp-act" will be the way to go.
viennaxmas
Perfect - thank you.
Yes, it is a pool thermometer, temperature only. t5temp works now.
Thanks for your help!
