Rain Multiplier
Posted: Fri Jun 26, 2015 1:21 pm
by lorenz1982
It is possible to increase the accuracy of the rain multiplier? I need 2 decimal. Should I put inside 0.25.
Re: Rain Multiplier
Posted: Sat Jun 27, 2015 1:09 am
It takes more than one decimal bit does not show it.
Will change with next update.
Re: Rain Multiplier
Posted: Sat Jun 27, 2015 9:21 am
by lorenz1982
Re: Rain Multiplier
Posted: Fri Jul 03, 2015 3:29 pm
by lorenz1982
admin wrote:It takes more than one decimal bit does not show it.
After entering the Rain Multiplier 0.25 I have a problem.
Today it rained 8mm and meteobridge writes the correct data.
On meteoplug cloud graphing instead it shows the figure of 32mm. It is not applied the correction factor.
I urgent need to resolve the issue. thanks.
Re: Rain Multiplier
Posted: Fri Jul 03, 2015 7:30 pm
does it allow you to set a calibration factor at the Meteoplug cloud service?
I would expect this being part of "sensors" page.
Re: Rain Multiplier
Posted: Fri Jul 03, 2015 7:44 pm
by lorenz1982
admin wrote:does it allow you to set a calibration factor at the Meteoplug cloud service?
In Meteoplug isn't possible to do it. The calibration function is disabled. See the imagines.
Re: Rain Multiplier
Posted: Sat Jul 04, 2015 12:53 am
Are you sure that it is disabled? From the screen dump it looks like being selectable.
Re: Rain Multiplier
Posted: Sat Jul 04, 2015 10:29 am
by lorenz1982
admin wrote:Are you sure that it is disabled? From the screen dump it looks like being selectable.
No, when Meteoplug is connected with Meteobridge the calibration function is disabled. You can see this because in the imagine the words are white.
Do you want we write us in private mode so I give you my password so you can do a prove?
Re: Rain Multiplier
Posted: Sat Jul 04, 2015 10:02 pm
by lorenz1982
Is there some solution? Maybe tomorrow here will rain again and I would like to solve the problem.
I have tried to insert a humidity calibration on Meteonbridge too and automatically it works in Meteoplug too. Why for the rain doesnt'work automatically?
