It is possible to increase the accuracy of the rain multiplier? I need 2 decimal. Should I put inside 0.25.
Rain Multiplier
lorenz1982
Re: Rain Multiplier
It takes more than one decimal bit does not show it.
Will change with next update.
lorenz1982
lorenz1982
Re: Rain Multiplier
After entering the Rain Multiplier 0.25 I have a problem.admin wrote:It takes more than one decimal bit does not show it.
Today it rained 8mm and meteobridge writes the correct data.
On meteoplug cloud graphing instead it shows the figure of 32mm. It is not applied the correction factor.
I urgent need to resolve the issue. thanks.
Re: Rain Multiplier
does it allow you to set a calibration factor at the Meteoplug cloud service?
I would expect this being part of "sensors" page.
lorenz1982
Re: Rain Multiplier
In Meteoplug isn't possible to do it. The calibration function is disabled. See the imagines.admin wrote:does it allow you to set a calibration factor at the Meteoplug cloud service?
- image.jpg (187.27 KiB) Viewed 5763 times
- image.jpg (184.9 KiB) Viewed 5763 times
Re: Rain Multiplier
Are you sure that it is disabled? From the screen dump it looks like being selectable.
lorenz1982
Re: Rain Multiplier
No, when Meteoplug is connected with Meteobridge the calibration function is disabled. You can see this because in the imagine the words are white.admin wrote:Are you sure that it is disabled? From the screen dump it looks like being selectable.
Do you want we write us in private mode so I give you my password so you can do a prove?
lorenz1982
Re: Rain Multiplier
Is there some solution? Maybe tomorrow here will rain again and I would like to solve the problem.
I have tried to insert a humidity calibration on Meteonbridge too and automatically it works in Meteoplug too. Why for the rain doesnt'work automatically?
