Missing? wind direction tags, 2 questions
Question 1: "prevailing" winddirection
I try to find the "prevailing" winddirection, and the wind direction range with a "lowest" wind-direction and a "highest" wind direction.
To display on the Steelseries gauges.
If the wind direction for today is mostly from the SW but varies between S and W the values would be 225 180 270
For Meteohub:
I thought the following tag would be the the most common or average wind direction for today
day1_wind0_maindir_deg
But is seems to be something else.
I can not locate any highest or lowest wind direction tags for today.
On Meteobridge
wind0dir-dmax the max direction for today seems to be correct
wind0dir-dmin seems to return 0
The average winddirection is only available for the last 60 minutes
wind0dir-avg60 is OK, but should be available for the whole day also
Question 2: The direction for the max wind:
In Meteohub it is all OK:
day1_wind0_gustspeedmax_ms 3.6
day1_wind0_gustspeedmax_time 20150901001403
day1_wind0_gustspeedmax_deg 265
But in Meteobridge the direction of the max wind/gust is missing:
wind0wind-dmax 3.6
wind0wind-dmaxtime 20150901001403
wind0wind-dmax??? for the direction this gust came from?
