Incorrect Rain Totals
n5sau@austin.rr.com
Post by n5sau@austin.rr.com »
I am a new user of Meteobridge and could use a sanity check. My rain totals seem to be off by 01". The first .01" registers correctly, but later on the rain total is .01" below where it should be. I'm running Meteobridge 2.5 (Jul 31 2015, build 6790), FW 1.4, and my weather station is a Peet Ultimeter 2000 running in complete record mode. I saw an earlier post about rain totals, but I thought I was at a later code level than the user in that post. I checked my Ultimeter console, and it did show the correct rainfall amount. I then checked it with Weather Display, again, it was correct. I then noticed that both Weather Underground and CWOP indicated .01" less than the console and Weather Display. I then checked the live data from Meteobridge, and it was .01" below the correct level. I would appreciate any words of wisdom. Thanks.
Regards,
Rich
Re: Incorrect Rain Totals
No idea, but 0.01" deviation is nothing that will make me diving into this.
n5sau@austin.rr.com
Thanks for your reply.
Regards,
Rich
