I accedentally removed the SD-Card when meteohub was powered on, I directly put it back mabe two seconds in between and now meteohub is not booting anymore!
So I quickly discovered that the sd-card partitions where damaged and none where there anymore.
I use R-Linux to recover most of the sd-card and I have quite much recovered.
Then I created a new sd-card and install a fresh meteohub image and let it update online to the the latest available v5.0j as this was that previous was installed too.
I regulary make backups of my weather data but not my settings, is there a way to set these settings back from my recovered data?
WinSCP could not write in folder HOME as there are some meteohub info stored, although I have logged as root and no read-only settings are used.
Any help on this is most appriciated.
SD-Card Meteohub partitions are gone (help)
Regards / Grüß,
Geert - ON1DQD
Geert - ON1DQD
- YJB
Re: SD-Card Meteohub partitions are gone (help)
Most of the settings are in /home/meteohub:
(I might have missed one or 2)
And the obviously your crontabs in:
clientraw.conf
clientrawdaily.conf
clientrawextra.conf
clientrawhour.conf
logger.conf
meteohub.conf
mwlive-us.conf
mwlive.conf
wd.conf
wmr928eval.conf
wswin.conf
xml.confAnd the obviously your crontabs in:
/var/spool/cron/crontabs/rootRe: SD-Card Meteohub partitions are gone (help)
Thanks for your fast response!
I wil try to transfer these files the the new sd-card if WinSCP does not complaint.
Regards / Grüß,
Geert - ON1DQD
Geert - ON1DQD
Thanks admin for your help !!!!
This is exactly what I was looking for.
viewtopic.php?f=60&t=10319#p18407
Core files to transfer are:
/data/weather/YYYYMM/* for raw weather data
/data/graphs/* for graph definition
/home/meteohub/meteohub.conf for most of config data
/var/cron/tabs/root for the upload/send schedulesRegards / Grüß,
Geert - ON1DQD
Geert - ON1DQD
