How to retrieve an old System-ID ??? **solved**
ON1DQD
Post by ON1DQD »
Does someone know how to retrieve an old System-ID?
I have my sheevaplug SD-Card replaced and now Meteohub needs to be activated again.
As I try to activate http://wiki.meteohub.de/Activation the system tells me:
Error: License key has already been used to generate an activation code: #########code##########
So I figured out that I have to transfer the old system ID tot the new system ID here: http://wiki.meteohub.de/Transfer
You wil be asked to enter:
old System ID
old Activation Code
new System-ID
But my problem is:
old System ID <- I do not have !!!!
old Activation Code <- I also do not have !!!!
new System-ID <- This I do have :-)
So how can I retrieve these old data from the SD-Card, if possible!?
If retrieving is not possible how can I get activated again as I only have the Lincense key available?
Regards / Grüß,
Geert - ON1DQD
ON1DQD
Re: How to retrieve an old System-ID ???
Post by ON1DQD »
Thanks to Meteohub great support it is solved now.
Regards / Grüß,
Geert - ON1DQD
We do keep track on activation code migrations and initial activation code generation. Therefore, we can help out in many situations, just contact "info(at)meteohub.de". Nevertheless, please also keep a copy of your credentials to keep our support efforts at a managable level.
