How to retrieve an old System-ID ??? **solved**
Posted: Sat Oct 10, 2015 10:01 pm
Does someone know how to retrieve an old System-ID?
I have my sheevaplug SD-Card replaced and now Meteohub needs to be activated again.
As I try to activate http://wiki.meteohub.de/Activation the system tells me:
Error: License key has already been used to generate an activation code: #########code##########
So I figured out that I have to transfer the old system ID tot the new system ID here: http://wiki.meteohub.de/Transfer
You wil be asked to enter:
old System ID
old Activation Code
new System-ID
But my problem is:
old System ID <- I do not have !!!!
old Activation Code <- I also do not have !!!!
new System-ID <- This I do have
So how can I retrieve these old data from the SD-Card, if possible!?
If retrieving is not possible how can I get activated again as I only have the Lincense key available?
old System ID
old Activation Code
new System-ID
But my problem is:
