What are these warning in System Log ?
ON1DQD
Post by ON1DQD »
Can someone explain why these error messages are in the SYSTEM LOG ???
Although my system is up and running.
1921-11-12T19:46:35.820493+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
1921-11-12T19:46:35.820514+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
1921-11-12T19:46:35.820526+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
1921-11-12T19:46:35.820541+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2015-10-11T15:43:42.649051+02:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2015-10-11T15:43:42.649073+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2015-10-11T15:43:42.649085+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2015-10-11T15:43:42.649099+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
cat: /data/weather/20*/raw: No such file or directory
expr: division by zero
2015-10-11T15:49:57.382483+02:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2015-10-11T15:49:57.382504+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2015-10-11T15:49:57.382532+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2015-10-11T15:49:57.382546+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2015-10-11T16:01:39.817994+02:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2015-10-11T16:01:39.818015+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2015-10-11T16:01:39.818043+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2015-10-11T16:01:39.818057+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2015-10-11T16:22:07.866428+02:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2015-10-11T16:22:07.866449+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2015-10-11T16:22:07.866477+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2015-10-11T16:22:07.866491+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2015-10-11T17:26:08.923114+02:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2015-10-11T17:26:08.923134+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2015-10-11T17:26:08.923162+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2015-10-11T17:26:08.923176+02:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
1921-11-12T00:33:58.893025+00:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
1921-11-12T00:33:58.893047+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
1921-11-12T00:33:58.893076+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
1921-11-12T00:33:58.893090+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
Is there a way to solve this or do I just forget about it?
Regards / Grüß,
Geert - ON1DQD
