Bug in the Meteobridge TP-LINK TL-MR3020 **solved**
MeteoOudkarspel
Post by MeteoOudkarspel »
I have found a bug in the Meteobridge TP-LINK TL-MR3020 (plus USB hub).
If I meteobridge set a fixed IP address on the check does not stay for the button after I clicked Save and apply "I have read and accepted the license agreement."
I do not like auto IP address as the option to use it every time different IP then.
Thank my heartfelt thanks for solving this bug.
Last edited by MeteoOudkarspel on Thu Jun 23, 2016 7:00 pm, edited 1 time in total.
Sincerely,
Re: Bug in the Meteobridge TP-LINK TL-MR3020 (plus USB hub)
Please use "save and apply and reboot" button as explained in the wiki.
Recommended way to have a device mapped to a fixed IP in your LAN is
to set the LAN clients to DHCP mode and to configure your router to
bind fixed IPs to defined client MACs. Advantages are:
1) there is one single point to manage all your LAN IPs ->the router
2) when you move a client device into another LAN or change the router,
your clients still get an IP via DHCP and stay operational.
Therefore, you might rethink your fixed IP preference.
MeteoOudkarspel
Thanks for your info. I had the meteo bridge set up a DNS address me router, but apparently it works not with the meteorological bridge. And have it set up a DNS address of Ziggo (me ISP), and now it works again.
Sincerely,
