MR3020 **solved**
MR3020 **solved**
I am new to meteobridge and I am trying to setup a MR3020 as a meteobridge. I was able to connect to the MR3020 and update the firmware but have not been able to connect to it since. I have tried everything I can find in the Wiki and so far nothing has worked. It doesn't seem to communicate with a usb flash drive. I have tried rebooting it by pressing the button until the led comes on then releasing it. I have followed the directions to configure it online and downloaded the file to a flash drive but it didn't work. I have did a full reset at lease three times by holding the button until the led flashed 5 times. I downloaded advanced IP scanner and I can find the MR3020 at 192.169.0.254 this is the address it was at before updating the firmware but it doesn't respond to pings or anything else. Any help you can provide will be appreciated.
Re: MR3020
Sorry, no idea what went wrong.
Re: MR3020
Just an update. I think the orginal Mr3020 was defective. I returned it and have installed meteobridge on the new one and everything is working correctly.
