Issue loading application stack
dhi20
Post by dhi20 »
Hi All,
I'm not sure if the issue is at my end or if the server with the application stack is down.
I restarted the meteobridge but it fails to load the stack. Pings in openWRT confirm connectivity.
Is anyone else having the same issue?
Re: Issue loading application stack
seems to be a forwarding loop hole in the router config, as no out going
http request (port 80) gets redirected to a device in the LAN.
