Precipitation Rate with no Precipitation (solved)
johnn
Post by johnn »
For no apparent reason my data uploaded to WU (from WRM200) shows a fairly constant Precipitation Rate (about 38.1mm), but there is no rain!
It may have been triggered by a single count, but if so it does not show in the data.
Is anyone aware of a configuration error that might contribute to something like this?? :D
Pepe
Re: Precipitation Rate with no Precipitation
Post by Pepe »
I might have a suggestion for you. My posts on this forum are in "Random wrong precipitation rate values" where I had the same type of issue.
My solution was simple and has worked perfectly since I made the adjustment below.
The erroneous posting of precipitation rate was resolved by decreasing the Rx Sensitivity of the setup from the -95 dB (default value) to -80dB.
Hope something like this works for you.
Pepe.
johnn
Post by johnn »
Thanks Pepe, but I don't think I have access to the Rx sensitivity.
I notice that I said I was using a WMR200, but that is wrong (I got my PWSs confused!). It is a WMR88.
Which Meteobridge release are you using? Did you check the release logs
if a newer release does fix this? http://meteobridge.com/wiki/index.php/Forum
johnn
Post by johnn »
admin wrote:Which Meteobridge release are you using? Did you check the release logs
OK, it may be before the 15th Nov, so I will have to get on site and check (haven't got remote access going yet!)
johnn
Post by johnn »
I have updated to the latest binary (as of the 25th) and it seems to be OK now.
