Delta selector not working
wsnoordbergum
Post by wsnoordbergum »
Hi all.
I'm running a template with the following line:
"[thb0seapress-delta60=nlbarotrend:---]"
Either I'm doing something wrong or there's a bug. :roll:
The result of this selector is "dalend" or FS in english.
I'm running the latest version of meteobridge and I've had the template reloaded several times.
On the trendpage of my site the barotrend is showing steady.
Since restart of meteobridge the value hasn't changed.....
Gr. wsNoordbergum
Re: Delta selector not working
wsnoordbergum wrote:Hi all.
Gr. wsNoordbergum
Confirmed at my site the same "error" occurs.
SW Version: Meteobridge 2.6 (Nov 25 2015, build 2939), FW 1.0
# thb0seapress-act.1:0    => 1012.3
# thb0seapress-val60.1:-- => --
# thb0seapress-val10.1:-- => 1012.4
# thb0seapress-delta60:--             => -0.5
# thb0seapress-delta60=barotrend:--   => -1
# thb0seapress-delta60=enbarotrend:-- => FS
# thb0seapress-delta60=nlbarotrend:-- => dalend
# thb0seapress-delta10:--             => -0.1
# thb0seapress-delta10=barotrend:--   => -1
# thb0seapress-delta10=enbarotrend:-- => FS
# thb0seapress-delta10=nlbarotrend:-- => dalend
Remarks:
1. There is no 60 minute-ago value for thb0seapress, but the delta values are there?
2. All delta values are in hPa, the converter gives the same result -1 / FS for delta values of -0.1 to -0.5 hPa
The delta values should lead to 0 / ST as described at: http://meteobridge.com/wiki/index.php/Templates
confirmed bug, will be fixed with next update.
wsnoordbergum
After a reboot to get the latest version of 27 nov I get the version of nov 25.
Is this the latest version?
Because I've seen no change in the Deltaselector issue.
Gr. wsNoordbergum
we had a delay on that.
